Results 1 to 7 of 7
Thread: Extremely incorrect Temp reading from Sun Touch controller
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    So, I have a Pentair SunTouch Controller and the water temperature reading is displaying 100 degrees +. True water temp is actually 52. Thing is, I can't change the water temp when I go into the menu options of the controller, will not let me lower the temperature.
    Any ideas?
    14100 gallon IG Gunite Pool
    Sapphire Smoke Quartz Plaster
    Pentair SunTouch Controller, Intelliflo 4x160 Pump, 520 Cartridge Filter, Intellichlor SWG System
    Legend Platinum Cleaner with booster pump
    My Pool Build
    Dec 2010
    San Diego, CA
    1,137
    Re: Extremely incorrect Temp reading from Sun Touch controller
    So when you go into the advanced menu you don't see options to calibrate the three temp sensors?
    Do you have the manual? If not download it from the pentair web site - towards the back there is a section on calibrating the thermometers and there is a table of resistance values vs temperature - pull the sensor wires from the PC board and measure the resistance - if it matches the resistance for 52 degrees then the sensor is fine.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    Yes, in advanced menu I can change temps but the water temp will not go below 100+ degrees.
    I don't know how to measure resistance. What would I need to do that? Multimeter?
    My Pool Build
    22,544
    A multimeter set on ohms is what you would use. I'm not sure what resistance you're looking for but it shouldn't be open.
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    Thanks. I have manual and shows what resistance should at certain temps.
    My Pool Build
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    Keep forgetting that I am still under warranty on the equipment. Just called the builder and they will come out and take a look at it.
    My Pool Build
    I had the same problem (I couldn't get the measured pool temperature below 130, when it was actually 68), and another website suggested a hard reset. I turned off power to everything for an hour, turned it back on and everything was fine.
    Linda
    12' X 36" Intex Metal Frame Set (2530 GAL)
    2500 gph Intex cartridge pump
    Aquabot Pool Rover Jr.
    Tons of trees and pollen
