Thread: To Strip or not to strip
    Hi All-
    In the process of bidding out a pretty complete pool overhaul (Plaster, tile, coping, drain, light and skimmer if needed). Have 3 bids and trying to compare apples to apples and everything seems to be lining up OK. I like 1 of the 3 contractors best as he runs his own small crew and has been around for 30 plus years. The one problem in he is suggesting sandblasting where the other 2 say strip to the gunite. The other issue is his sandblast price in more than the other strip prices.
    I have 3 questions:
    1. What is the determining factor for strip vs. blast?
    2. How do I ask best specific questions of the contrator without coming off as a know it all or challenging his expertise. I have a pretty good background as an owner/builder on bathrooms and the like but NO pool experience. I want to show respect for my contrators expertise and still be able to ask specific questions.
    One guy wants 40% up front and I am only willing to go 10% - 40% is too much or is it?
    Pool Facts
    18k gallon with spalling plaster
    San Francisco Bay Area
    Re: To Strip or not to strip
    Stripping it to the shell is always the best alternative when your doing a major renovation. You don't have to worry about what might be weak or in the process of delaminating. The only time we sandblast is if there is paint involved and because of the high cost we usually end up chipping them out instead.
    Give the contractor that you like a chance to quote the strip option.
    40% upfront is pretty hefty. You should negotiate payments that reflect the progress of the job.
    Jan 2011
    Riverside, CA
    352
    I'm almost positive 40% up front is illegal in California. My PB was only able to collect $1,000 when we signed the contract. I cut checks as different stages are completed. Nothing is paid for before it is done (except the final check for the Plaster).
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
