Thread: foamboard for pool bottom?
    May 2008
    South Central PA
    20
    Hi all,
    Just notice water level was gone way down in pool went to investigate have big rip in liner. So when I replace the liner I saw some
    people use foamboard. I currently have a sand base which overtime of seven years has gotten ruts in. If foamboard is used
    my concern would be if any wash out would happen underneath or if the board cracks any thought or suggestions
    pool is 24' round 52" high
    Mike
    13,500 gallon AGP, 1-1/2hp pump 150# sand filter
    22,553
    Re: foamboard for pool bottom?
    If cut and taped properly you should never have problems with it. Use the foam cove on top of it and you should be good.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    May 2008
    South Central PA
    20
    Any suggestions on thickness of board?
    Thanks
    Mike
    22,553
    Most people use ½" but there are threads of people using up to 2". I'd say it's a personal preference.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    I have been using 2" foam for about 8-9 yrs now. I learned about it from a friend with a 24' perm. pool, he also has 2". The 2" has better insulating properties and holds up better than any otherthickness. Yes it is 2X the $ but it has been worth it to me.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    May 2008
    South Central PA
    20
    Thanks for the info. I haven't replaced it yet just waiting for it to get warmer. I was concerned with 1/2 foam because I have steps vs ladder sitting in the pool wasn't sure how it would hold up
    Mike
