Thread: Haywood T400 Heater problem
    My heater (Haywood T400) has started to rumble. It still heats the water, but it sounds like it is getting ready to take off like a rocket ship!
    I thought there might be some stone stuck inside, but that doesn't appear to be the problem.
    20 x 54 Sharkline Oceanic
    1 1/2 hp White River
    22" Sparco Hi-Rate Sand Filter
    Nature 2 Sanitizer
    dmanb2b's Avatar
    Apr 2009
    NY
    3,730
    Re: Haywood T400 Heater problem
    Welcome to TFP
    Oct 2010
    Georgia
    317
    Rumbling, banging or bumping is normally a sign of inadequate water flow through the heat exchanger.
    Here are a couple of easy things to check.
    Be sure your pool filter is clean. If you are using a two speed or variable speed pump, adjust to higher output setting.
    If the problem persists, contact your local service technician to check for blockage inside the heat exchanger.
    Continued use of the heater with inadequate water flow could lead to extensive (expensive) damage to your unit. Have it serviced soon.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    The most common cause of low water flow is a dirty filter. Cleaning the filter is a good place to start.
