Thread: ph/chlorine tester
    ph/chlorine tester
    Has anyone used this ph tester?? I was thinking of getting one of these..
    http://cgi.ebay.com/NEW-SWIMMING-POOL-S ... 1650wt_907
    18,000 Gallon IG, Gunite, Cartridge filters
    Rainbow 320 Chlorine feeder (not in use anymore), 2.0HP Pentair WhisperFlo
    Legend Platinum Hummer Pool Cleaner
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Re: ph/chlorine tester
    I've never used one, but it only measures chlorine from 1.2-1.7 ppm, which isn't going to help much unless you're using a very small amount of CYA in the pool(12-17ppm). I can't imagine it's very accurate, pH or chlorine.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    The PH test in that tester is not precise enough to be useful, and the chlorine test doesn't really work at all. There are more expensive PH testers that are fine, but testing chlorine electronically is very problematic. The only electronic chlorine testers that work usefully are colorimeters over $100, and even then there are significant limitations.
    Guest
    That looks like it came out of a Cracker Jack Box...
    Thanks guys I will keep to the old fashion way of testing....
