Results 1 to 12 of 12
Thread: WARDSNTX First TF-100 Test
    wardsntx's Avatar
    Jun 2007
    Spring, Texas
    223
    Ok,
    tested the water for the first time today since partial startup yesterday and remainder this morning. Here are my results
    FC - 7.5
    CC - 0
    TC - 7.5
    PH - 7.8
    TA - 180
    CH - 180
    CYA - 20- I could still see black dot in tube after completely full though it was faint.
    Any immediate advice?
    The TA is high, but I guess that is contributed to the large amount of Trichlor tabs they put in??? (5) in each skimmer to be exact.
    My CYA reading is probably lower than 20 since I emptied the whole test container and could still see the dot. Did I fail my test?
    Thanks!
    Jay
    36' x19' Freeform, 16' waterfall w/ groto and slide, 5' x 10' sundeck, 12" raised spa. Pentair IntelliTouch, Pentair IntelliFlo 4 x 160, Master Temp 400, IntelliChlor Chlorine generator, Aqua Blue PebbleSheen
    Mar 2007
    Ontario, Canada
    294
    Your FC is probably a bit high, you can probably bring your CYA up to around 40-50 and drop your FC down to
    3-4ppm. You can also drop your pH down to around 7.6. Your TA could come down a little to around 120ppm.
    Mar 2007
    San Rafael, CA USA
    12,082
    The use of Trichlor pucks as chlorine gets added does not change the TA, though the pH goes down a little. As the chlorine gets used up, the pH goes down more as does the TA. So I don't think the high TA is from the Trichlor or its effect on pH.
    I suspect the high TA is from the fill water. You might test that separately to see.
    wardsntx's Avatar
    Jun 2007
    Spring, Texas
    223
    should I just monitor over the next week and let the trichlor tabs do their thing? I had tested PH yesterday and it was at 8.2, now at 7.6, so it is slowly going down to an acceptable level. This will help reduce TA as well correct? Before I go adding too much to the water, I am tempted to wait a few days and then check again before reacting. I thought that for only the second day after start up that these numbers were ok albeit not perfect...am I wrong in my assumption?
    I think I should do the CYA test again...just don't feel comfortable with the results from the first attempt.
    Jay
    Mar 2007
    Ontario, Canada
    294
    you can double check your CYA by taking a sample to the pool store.
    30,421
    Yeah, I think you're on track to keep doing what you're doing and let things settle in. Your pH is under control, and the pucks are giving you some sanitation. Yes...T/A will come down with pH.
    Trust your CYA test over the pool store's. They'll probably use a strip (not good for CYA). Is there a reason you don't trust your CYA results? You haven't mentioned adding any and the pucks will not provide very much so it seems to me <20ppm would make sense. It's not a very dramatic test so I think there's a tendency to assume it's not working properly when you first do it. Your description sounds like you did it correctly.
    If you're counting on the pucks to bring you up to a good CYA level, that'll be a very slow process. I would suggest purchasing enough separately to add 20ppm or so to your pool and then let the pucks do the rest.
    ktdave's Avatar
    Katy, TX
    888
    Jay,
    Welcome to the other side! Your initial results are pretty good. I agree with Duraleigh that your CYA test was done properly. When you add the CYA, see how much you need to add for your goal (I would shoot for about 30 right now) on Jasonlion's calculator (Pool Calculator)Add that much and wait at least a week before testing again. Since your going to be using a SWG, if you overshoot it is not a big deal because your final goal will be 50-75 ppm. You are going to find that maintaining your pH is going to be a PITA for about 3 weeks, then it will level off. I went through 4 gal. of muratic acid in the first 3 weeks and I found out real quick to figure out which way the wind is blowing before opening the cap on that bottle . Also, you want your TA around 90-100, but that will drop with all the acid you will be adding.
    ENJOY IT!
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    wardsntx's Avatar
    Jun 2007
    Spring, Texas
    223
    Thanks guys...
    I hope I am not seeing algea bloom already, but yesterday and today when I get hoe from work to brush the pool, there is a brown powdery substance in the pool and the spa. When I sweep it just clouds up the water. The same type residue is in the skimmer that seems to be clogged, It seems like DE, but they told me they didn't add any. If I aggetate the water i n the skimmer, the water turns muddy brown and you can't even see the skimmer basket.....I tried to unstop the blockage , but it is solid and it is the main drain suction (front hole).
    <a></a>
    <a></a>
    Jay
    That looks like silt or dirt to me. DE would be whiter. Algae is hardly ever that color, except sometimes when it is dead.
    Did it go straight from clear to that color?
    30,421
    Hi, Jay,
    I'd be willing to bet that's not algae. I'd also be willing to bet that it's something involved with the construction of your pool. Does your whole pool look like that?
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Jay,
    Are you running your pumps 24/7 at the moment? My pool ran 24 hours a day for at least a week at startup. I had similar issues at startup. My blockage was on the pressure side. I was in fear of running a ditch witch through the line but I did run my Fish Tape through the line to the blockage. Once I found it, I rotated the line around and Blam... Out came a huge chunk of mud/dirt/clay... All in a clean pool of course but it was clear. If you have resolved your issues with your PB, then I truly suggest calling him and getting him involved. keep us posted.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    wardsntx's Avatar
    Jun 2007
    Spring, Texas
    223
    Yeah...I almost took my plumbers snake to it, but it as right at the skimmer. I beat the **** out of the blockage with a screw driver and hammer and was able to get a few chunks out, but it keeps going past the depth I could get any leverage to hit my screw driver ( was afraid it would break loose and...oops, there goes the screw driver too!) Anyway, they are coming out tomorrow to check it out. I am pretty sure the debris I see in the pool isn't algea, but just debris from this slowly passing throught the system.
    Yes, Pump is running 24/7
    I'll keep you updated.
    In the meantime, I am heading out to buy some more tablets. Any reccomendations on the best ones to use? Tri-chlor?
    Thanks again guys for the help....it's a little scary being on this side now...I feel like the new kid starting a new school half way through the school year !!!!
    Jay
