Thread: Maggets in pool
    Maggets in pool
    Hello Everyone.. I just found this website and seen that it has alot of helpful information. I recently found maggets in my pool and i have no hanging trees around, but i do have dogs. Not sure how to get rid of the maggets. Any help would be appreciated...
    Thanks.
    5,100 gallons, fiberglass, cartridge filters, suction side vacuum.
    Swimming pools.....the difference between **** and an Arizona summer.
    Hi, and welcome to TFP!
    Are you sure they are maggots, and not mosquito larvae? I don't think maggots can live in water... they are fly larvae, and are usually found on rotting flesh or fecal material.
    Get your water tested and post your numbers here and we can better assist you!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Arizona
    924
    Hi and welcome to the group.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
