Results 1 to 11 of 11
Thread: Confused about "closing" AGV pool for the winter
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Since we have decided to "close" our pool this winter by just covering it with our solar cover and using the leaf net we bought I have some questions:
    1) How will this way of closing the pool affect the "shock and algae" treatment. Will we need to recheck our chlorine or even add some during the winter?
    2)Will we be smart to run the pump a few hours during the night maybe 2-4 hours/7 days a week during the coldest months because it does go below freezing sometimes here. Since we are running the pump will this have any affect on the chlorine we put in to shock it for the winter or better yet how will it affect the algicide we added to prevent algae growth?
    I think thats all the questions I have ...
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    30,414
    I believe you could approach it simply by maintaining the pool much the same way as if it were open.
    Run the pump from time to time....circulation is always good.
    ALWAYS run the pump when you suspect night time temps might feeze your pipes.
    Add a little chlorine when it drops to zero. You won't need much when the water gets cold.
    As we discussed before, dump that leaf net before you get a big load....you'll be happy you did and sad if you don't!
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Ok, were going to give it a shot !
    Since we are switching to the BBB method and we have an auto chlorinator and wont be using it can we actually take it off the line and not use it or should we just keep it turnd off with the chlorine tube empty? Not sure how to approach that ...
    Les
    Helpful Links:
    30,414
    If you mean disconnect it from the system, that'll work. If it's not easy to disconnect, I think your best bet is empty but with water circulating thru it.
    Take my opinion for what it's worth.........I don't have one so others may have a much better idea.
    Guest
    if you kept it dry all the colorine resadue would cause clorine gas and the next time you open it, it will hit you like tear gas. also i think where you remove it you would have to plug the lines or when the pump runs with out it the water will squirt out.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Dave, To actually remove it I would have to cut if off the line and insert some pvc pipe to replace it. I am pretty niffty with my hands and tools just not sure which is best to do
    Les
    Helpful Links:
    30,414
    Well, you've got me interested now. I wouldn't cut it loose....they're handy for vacations, etc. Could you leave it online and put a tennis ball in it for expansion in case it froze?
    Guest
    Quote Originally Posted by TizMe
    i think your best bet is to just leave it connected and let water run through it, that way if you ever need it for some reason, you have it.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I can leave it attached and online. I guess it will be best to leave it open with water running through it and not fill it with tabs unless we are going to be away for any extended amount of time.
    Les
    Helpful Links:
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I will steal a tennis ball from one of the dogs and see how that works... wish me luck getting a ball from the dogs !
    Les
    Helpful Links:
    Guest
    my dog is obsessed with tennis balls, if i take one from him to use it for somthing, and he sees me do it. lets say i take it and put it in the fridge, if he saw me do it, he will stay there and wait for it. only leave to eat or drink, but will always stay there, but i give it back so he gets a life again .
