Results 1 to 10 of 10
Thread: Tell me about LED lights....
    Wantapool's Avatar
    Jan 2011
    North of Atlanta, GA
    4
    Why do I want LED lights vs halogen? Is their lifetime really that much longer? I don't think I want a "light show" feature... they just seem disco-y to me (no offense to those who like them ) . My brother keeps telling me I need LED ... I trust him, but he's only 1 pool owner. I need more reviews. Thanks!
    Re: Tell me about LED lights....
    Yes, the "bulbs" really do last far far longer for LEDs. That can be important with an underwater light, as changing the bulb is a project. LEDs also tend to be just slightly safer to use. However, LEDs tend to not be quite as bright as similar halogen lights.
    You don't need to use the light show feature, even if the light you purchase has it available. Several of the common LED models include it as it tends to be popular and doesn't really cost them much of anything extra to include.
    Jan 2011
    153
    You can go with Pentair Intellibrite white lights..
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    Quote Originally Posted by Wantapool
    I went with LED in my pool because of the many color choices. I don't use the shows at all. The LED lights use much less power than the standard bulbs but the extra expense of the LED light probably makes this a moot point. I guess it would depend on how often you use the light and how long it lasts. My LED light only uses 50 watts and is supposedly rated for 50,000 hours. That's a Jandy Watercolors light.
    http://www.jandy.com/html/products/l...rcolors.php#pf
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    South Central NJ
    3,192
    LED fixtures don't need bulb changes. They are sealed units. They are rated, as Jason said earlier, at about 50,000 hours of life, white or color. At 12 hours of use per day, every day, they'll last about 11 and a half years. Halogen or incandescent bulbs would get swapped ever couple years along with it's lens gasket, at best. Color changing Halogen fixtures will also need a new color wheel in that time frame. Halogen fixtures usually have more than one bulb too.
    While a 500 watt, white, incandescent fixture will put out more lumens per light fixture, the Halogen and LED fixtures are fairly close to each other, comparable to a roughly 250 to 300 watt incandescent fixture. The 500 watt can light a 20x40 pool but it will take 2 LEDs.
    LEDs use between 50 and 90 watts of power but put out as much light as a 200 to 300 watt incandescent, depending on the manufacturer. Lets take the power usage, bulb and gasket and color wheel costs into account and the payback isn't that long considering the price. If's even faster if you don't change the bulb yourself.
    There are a lot of positives with LED fixtures.
    Scott
    Owner of - PoolGuyNJ LLC
    Wantapool's Avatar
    Jan 2011
    4
    So if I was quoted for one 500w light for my 18 x 32 freeform ... If I decide to upgrade to LED I will need 2? Hmmm, so many decisions!! I think we'll go for it, better spend some extra $$ now, then regret it later.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    So if I was quoted for one 300w light for my 18 x 32 freeform ... If I decide to upgrade to LED I will need 2? Hmmm, so many decisions!! I think we'll go for it, better spend some extra $$ now, then regret it later.
    You will not regret getting led lights. We initially had a 500watt light and quickly changed to a pentair LED. We love the various light shows and use all of them on a frequent basis
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yep, you'd probably need 2. More expensive yes, but you'll also have more even lighting throughout the pool rather than having one blinding light at one end. If it were me, I'd put both lights on one long wall, facing away from the house/sitting area(s) if possible.
    Jan 2011
    Riverside, CA
    352
    I putting 4 LEDs in our pool. We'll see how much I use the Disco setting on the Jandys :P
    I'm going with all LED outside, so I can run them as much as I want without too much concern over the cost.
    At about $400 each, I have no clue how long it will take to payoff the investment.
    I went to EWing the other day and he gave me a rough figure of 2-3 years to pay for the LED Landscape "Investment"
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    I highly recommend the Hayward ColorLogic 2.5 LED's. We just installed 2 in a pool and they look incredible. Everyone wants them now. They have 12 programs to select from. you can select a fix color..they have 5 fixed colors. just works off the light switch. turn off and on the light switch and you toggle through the 12 programs.
    These are the only lights we recommend now. forget the white lights. the colorlogic have some really nice colors to chose from and will enhance your pool experience.
