Thread: Jandy LT Heater - Ignition Problem
    Today the Heater stopped working with an AGS code.
    Gas pressure is OK, verified.
    I measured 59 ohms on the ignitor when disconnected from the system
    I measured 240 volts to the board between the controller and the ignitor
    I measured 43 volts to the ignitor when the system is on.
    I measured 59 volts to the ignitor when the system is trying to ignite.
    Ignitor does not glow.
    Gas valve is operating normally.
    Any Ideas?
    Pool: 15,000 gallon 32'x18', 3'-6' deep in-ground gunite pool, Sta-Rite 3 125 GPM 2-filter cartrige, 1.5 HP Sta-Rite pump, solar heater, Goldline SWG, Jandy controls, opaque automatic CoverStar solar pool cover, 3 waterfalls (not from spa).
    Spa: 485 gallon in-ground square acrylic over fiberglass suspended over gunite Sunset brand spa, isolated system, natural gas heater, 2-speed (4hp/11hp) main pump, 3hp booster pump, chlorine sanitized.
    To my pool store owner, nothing is more important than my pool and my money.
    Richard's PoolEquations Spreadsheet
    South Central NJ
    3,192
    Re: Jandy LT Heater - Ignition Problem
    Igniter is shot I think. The resistance, IIRC should be about 8 ohm.
    Scott
    Owner of - PoolGuyNJ LLC
