Results 1 to 9 of 9
Thread: How often to adjust pH?
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Hi,
    Is it fine to adjust pH once a week or is this something I should be doing more often? I have a salt water system and I read on here I need to keep my pH at 7.5-7.6 but everytime I test it is 8.0. I then drop it to 7.5 but I don't know how long it stays at 7.5 before it bounces back up to 8.0.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Re: How often to adjust pH?
    Quote Originally Posted by Aquatica
    Hi,
    I'd test it daily until I learned how fast it changes. Then adjust accordingly. Might be every day, might be every three - you'll never know unless you experiment.
    Plug your numbers into Pool Calculator. See what the CSI is - you want to keep that in the safe zone, however often that means adding acid.
    If you plug your numbers into Pool Calculator and something is way out of range, you can always post another thread for help with it. Be sure to select the finish and SWG down at the bottom.
    Dec 2009
    Central Massachusetts
    2,690
    How often do you test your pH? You should really check it daily. What is your TA? How are you testing your water?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Every pool is different, and a pool will change with time as well. Mine climbs about 0.2 per week, so I tweak it on Saturday or Sunday and don't worry about it for a week. Mine used to climb insanely fast like yours, and I checked it daily and usually adjusted it daily.
    susa's Avatar
    Oct 2010
    Deep South
    578
    ....or one could install an automatic system for about $200 and not have to breathe fumes or worry about adjustments.... Simpool pH in my sig (just another happy customer and they shipped in one week from Italy to USA)
    Mar 2007
    San Rafael, CA USA
    12,082
    My pH climbs around 0.2 per month, but I have an electric mostly opaque safety cover so outgassing is minimal though the pool is used 1-2 days per week and longer on weekends. I use 12.5% chlorinating liquid added around twice a week and I check the pH every week or two and add acid around once a month or so as needed. Those pools with higher TA, lower pH, more aeration, and SWG systems tend to rise in pH more quickly.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by susa
    Certainly an option in way of automation, but we'd still advise regular manual testing of PH and other water chemistry parameters to ensure everything is working the way it should
    The quick answer to the OP is to adjust it down everytime PH rises to 7.8 and above. If you experience frequent PH rise, lowering your TA to around the 60-80 range and possibly using borates could help counter the frequent rise in PH and make things a tad more stable.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Thanks for the replies. Much appreciated.
    I guess I will test daily until it levels out. My TA is 80 and still seems to go up.
    May 2009
    Dallas, TX
    784
    Lowering your TA might help. I lowered mine to 50 and it did slow the pH rise. If you do this you may have to adjust your CH a little higher to keep your CSI within range.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
