Results 1 to 18 of 18
Thread: Going to be cleaning filter sometime soon.
    Mar 2010
    Spring, TX
    1,082
    I will post pics so people can see what a mess a DE filter can get. I did this last time I cleaned, but did not take pictures from beginning to end.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Going to be cleaning filter sometime soon.
    Have someone standing by at the end of the backflush hose when you throw the switch, to get pictures of the grey sludge. I wasn't thinking when I did it, and by the time I got the camera, it was nowhere near as disgusting as the first few seconds.
    Mar 2010
    Spring, TX
    1,082
    Well cleaned out the filter and it was no where near as dirty as it was last time. I actually had very little DE filter buildup and did not have to even take it apart to clean. I was able to hose it down and remove very little DE that was stuck in between the filters. Pressure went down from 15 to about 5 so it must have been dirty, but I guess the backwash knocked a lot of the DE out. So this year I again used the silicone sealant, so we shall see if it held this afternoon when I go to turn the filter back on. Let it sit for a while to make sure it got a good seal.
    Now here is my question and it seems I may have an issue at sometime. Last year I used a silicone based sealant to seal off the o ring around the filter and it did a fantasic job. So this year I was going to replace the O Ring. Went to the store and picked one up. Got home and it is about 2 inches too big. Went back to the store and we then looked up in the book to make sure we got the right one and we did. It was an 18 inch O ring, but is still too big. We measured it up to the old one and it was the same size.
    So my question is, what will I do when I need to replace the O Ring if the new correct one is too big?
    Thanks.
    Mar 2010
    Spring, TX
    1,082
    Here is my filter
    Jan 2011
    153
    There is 2 different tank orings for your filter.. One of the is fat and sits in a channel, the other is thinner and sits around a ring.. I believe this is the one you need 152127, the other is 071442. Where in Spring are you, I can maybe lead you to a store which can help you better...
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by Keven
    The 152127 is 18 inches and I believe that is the one that I got. Edit: The 152127 is the one that I got.
    I am around Klein high school. I tried warehouse pool supply on 249 and 1960. I was going to go to leslies, but they seem to never have stuff in stock.
    What do you mean when you say one is flat and sits in a channel and the other sits around a ring? I am confused now as to why I would have two different o rings or the o rings just made for two different type of filters. The old one I have now seems to be flat on both sides which is maybe what you are talking about. The other one was round.
    Thanks.
    Jan 2011
    153
    The reason for different orings is they changed the filter lids.. The fat oring is on the outside of the filter then the lids go's around it.. The older style sits on top of the bottom of the tank and the lid sits on top of the oring..
    Professional Pools on Louetta just pass Klien Church Rd is good to deal with..
    I hope this helps out better, I have a hard time going frm my head to the keyboard making it sound right..
    Mar 2010
    Spring, TX
    1,082
    I will give them a try. I drive by them all the time. Funny thing was the 152127 is the one I got and it was round. Are you in the spring area as well since you seem to know the area?
    Jan 2011
    153
    Yes I live in Spring even went to Klein, I don't do any work in Spring all my work is North...
    Mar 2010
    Spring, TX
    1,082
    Which Klein school and what year did you graduate. My wife went to K.O.
    Jan 2011
    153
    I went to K.H.S graduated in 94... Alot of my friends went to K.O graduated from 93-96..
    Mar 2010
    Spring, TX
    1,082
    Oh ok she was 2002. I graduated from humble in 98. Good to know there is someone in my neck of the woods. I live around Klein High School.
    Jan 2011
    153
    My wife graduated from Splendora in 00.. It is nice to know somebody else in the same area... I never get down by you unless we go out to eat at Fat Mikes, Smashburger or Chi (sp) Burger...
    Mar 2010
    Spring, TX
    1,082
    Fat Mikes right by HEB?
    Jan 2011
    153
    Yes that's it... Use to like the Philly buts off the menu now.. Was Professional Pools able to help you...
    Mar 2010
    Spring, TX
    1,082
    I got a response back from them and they have the same o ring I got at warehouse pool supply. They are going to call the manf to see if they have pre form one already. I got home today and turned on the pump and I am still getting some leaking, but not near what it was. I am thinking of maybe sealing it with some silicone sealant on the visible leaking.
    Another questions is how often to filter pumps have to be replaced?
    Jan 2011
    153
    Try this with the pump off hit the tank band with a hammer all the way around once that should give you more slack in the spring, after that go ahead and tighten the bolt again.. That should help you get the filter to seal up.. You might have to it one or two more times..
    Mar 2010
    Spring, TX
    1,082
    I tried the hammer trick as well already. The two bolts are on there pretty tight as the sides are about 1-2 inches apart where the belt connects around the tank. The belt appears to already be right up agains the tank. And I do not have any springs, just a bolt with a nut on the end. Never had springs at all.
