Results 1 to 18 of 18
Thread: stuck cap on Triton II TR-140 sand filter
    Oct 2010
    Raleigh, NC
    7
    We have 3 of these filters on our 100k gal pool. They have a screw on cap (about 10 in diameter) with a pressure gauge on top of the cap. I've been fighting a losing battle with one of the caps and I'm looking for any tricks to get it off. I've broken one of the plastic wrenches that fits over the fins on the cap. I've tried getting more leverage with a length of pipe on the wrench handle. I've tapped on the cap with a rubber mallet, scraped around the rim, applied various lubricants. It's stuck and I'm stuck. Any ideas? Thanks. --Fred
    100K gal. IG, plaster,3 sand filters, ITT Mohler cast iron pump, 7.5 hp motor, 350 gpm
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: stuck cap on Triton II TR-140 sand filter
    Hair dryer?
    South Central NJ
    3,192
    Get a replacement cap, o-ring and pressure gauge 1st. Then cut the old one off. If it's stuck, force it. If it breaks, it needed replacing anyway.
    Scott
    Owner of - PoolGuyNJ LLC
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Quote Originally Posted by FredW
    Have you relieved all the pressure/vacuum?
    Otherwise, yeah, get new ones. Be exceedingly careful when cutting near any threads, you don't want to bugger them up.
    30,415
    I have that same filter and those caps are a real pain. I put Vaseline on mine each time I remove it (seldom) and that probably is the only reason I haven't had to cut it out.
    Oct 2010
    Raleigh, NC
    7
    Thanks for the replies. Gave it one more try with no pressure or vacuum and, what the heck, even tried the hair dryer. No luck. Will order the new closure and get the sawsall and vaseline together for the repair job.
    30,415
    Hi, Fred,
    One word of caution....PoolguyNJ suggested that vaseline can be corrosive to some o-rings and I believe he is right. My o-ring is apparently impervious to it but it's 8 years old now and they may have changed.
    There is a product called "pool lube" (I think that's the name) that will likely be a safer choice.
    JoshU's Avatar
    New Orleans, LA
    542
    There are may lubes out there for o-rings. A common brand is Magic Lube from Aladdin. These lubes are telfon based making them friendlier to the o-ring material.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Jun 2014
    Chandler, Arizona
    88
    I'm resurrecting this thread because I'm facing this very issue with my Triton II's closure cap. I'm going to have to use a saw of some sort to remove it. Any recommendations on the type of tool(s) I should use are appreciated. A sawsall was mentioned as a possible tool but I'm thinking this might be more effective: Rockwell RK3441K Compact Circular Saw Kit - Power Circular Saws - Amazon.com
    Thoughts?
    28k gallon in-ground pebbletec pool w/waterfall and grotto feature
    Triton II sand filter
    "The Pool Cleaner" 4-wheel vacuum
    1.5hp main pump; 1.5hp water feature pump
    Taylor K2006 test kit
    Try drilling a hole through both sides of the dome and then stick a metal rod through the dome and unscrew the dome with the metal rod.
    Support the site
    30,415
    I have that same filter and I can attest it is a booger bear to remove. I got it loose by using the plastic tool and tapping the ends over and over with a rubber mallet but I thought I was going to break it.
    I can't quite picture JamesW's fix but he has a ton of experience.....I think I was just lucky.
    Pump Strainer Pot Lid Handle Cracked Off!!!!!!
    Try the wrench first. Try tapping the handles with a rubber hammer. Then try extending the handles with pieces of pipe. As a last resort, try the metal rod and then replace the dome.
    Support the site
    Jun 2014
    Chandler, Arizona
    88
    Some good suggestions here. I gave that thing all my strength and it just looked at me and laughed. I'll give a couple of these suggestions a try tonight. If unsuccessful, what are your thoughts on using this to cut it off piece-by-piece:
    Dremel 4000-2/30 120-Volt Variable Speed Rotary Tool Kit - Corded - Power Rotary Tools - Amazon.com
    I just don't have much confidence that anything else will work.
    Here's another idea.
    1) Put on the lid wrench.
    2) Find a cylinder that perfectly fits over the dome down to the flat part.
    3) Make the bottom water tight with glue or tape.
    4) Fill the cylinder with ice water.
    5) Wait a few minutes for the dome to cool and shrink.
    6) Unscrew with wrench.
    Support the site
    Jul 2015
    Gilbert,AZ.
    123
    I have a steel wrench, with long ends, never a problem for me.
    Jun 2014
    Chandler, Arizona
    88
    Quote Originally Posted by pool&spatech View Post
    Well who woulda thought that a runner mallet and my wife holding things still would do the trick. I'm happy to post this pic:
    Appreciate all the advice, folks!
    Good job. Thanks for the update.
    Support the site
    Jun 2014
    Chandler, Arizona
    88
    Quote Originally Posted by asusundevil View Post
    Well who woulda thought that a rubber mallet and my wife holding things still would do the trick. I'm happy to post this pic:
    Sent from my VS990 using Tapatalk
