Results 1 to 7 of 7
Thread: measuring bleach strength
    Oct 2010
    Melbourne FL
    12
    Is there an easy way to test the strength of bleach?
    I figure if you dilute it 10000 times then you can test using the conventional way.
    But whats a good rule of thumb to do the dilution?
    For whatever reason my last round of bleach from the pool store didn't seem to cut it.
    Sorry if this is a redundant thread. all my searches turned up as testing the pool water not the actual bleach
    11000ish gallons, cartridge filter, IG (in ground), plaster, 1.5 hp pump, screen enclosure
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: measuring bleach strength
    nope...valid question...easiest guage is using the pool volume. One gallon of 6% bleach should raise the FC in a 10K gal pool by 6ppm. One gallon of 12% = 12ppm, etc...so if you are using 6% bleach in a 11k gal pool, you should get an FC boost of about 5.5ppm +/- 0.5ppm, after adding one gallon, assumming it's a "fresh batch"
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Oct 2010
    Melbourne FL
    12
    thank you.
    My 10.5% bleach measured (using my pool volume) to be 8.5%
    Do the pool stores store their bleach in translucent plastic towers outside the store?
    I wonder if I just have old bleach since its winter time.
    Kes's Avatar
    Apr 2010
    Worcester UK
    46
    It can be done by dilution fairly easily with a set of digital scales. I set the scales to zero (grams) with an open container on. Then put in about 3-500 grams of clean water, add 100 g of bleach and top up to 1000 g. That's dilution of 1/10. Stir and take out and save a plastic cup full.
    Empty and rinse the container, put back on the scales and repeat the process, this time adding the 100 g from the plastic cup. This dilutes to 1/100. Discard/rinse plastic cup, take another cup full. Do twice more - four in total - and that's 1/10,000 (as the bleach is already n/100 dilution this brings it to ppm strength). A final stir and test the result with the pool kit.
    If my maths is rubbish I'm sure someone will correct my foolishness.
    The reason I do 100 g to 1,000 g and add the 100 g in the 'middle' of the dilution is to lessen the effect of slight inaccuracy. You also need clean un-chlorinated water to do the dilution.
    (Edit: posted before I read Ohm_Boy's link, which says much the same thing.)
    11,000 Imp galls inground hopper 15' x 35', Delifol liner (vinyl), sand filter, Abrisud Classic cover, Palintest 315C test kit
    Jan 2009
    Cupertino, CA
    1,966
    Just for completeness: 1/2 tsp 6% bleach in 4 gallons* unchlorinated water should read as 10ppm.
    (That's approx 6000:1 dilution. Measuring the 1/2 tsp precisely is the hardest part.)
    --paulr
    * U.S. not Imperial, not that I think anyone really still uses Imperial gallons, I'm just showing off
    BBB "Intermediate Swimmer"
    Kes's Avatar
    Apr 2010
    Worcester UK
    46
    < not that I think anyone really still uses Imperial gallons....>
    Oh I don't know, old boy, still a few of us left in the old Empire.
