Thread: Pool Calculator dumb ?
    When it ask for temperature in the Pool Calculator what temperature is it asking for?
    How hot or cold it's going to get weather-wise? Or the water temperature? or ???
    I looked through all the directions and didn't find anything that specified what is meant.
    Thanks
    17,000 gal IGP, White plaster, Hayward Swimclear Cartridge Filter system, Sta-Rite Max-e-pro 1/2 hp pump; 3/4 hp booster pump
    Sacramento, CA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Re: Pool Calculator dumb ?
    Water temperature. That is one of the factors in calculating the Calcium Saturation Index.
