Thread: Lowering CYA
    Oct 2010
    Houston, TX
    152
    Lowering CYA
    Hi, my CYA is 160 due to trichlor tabs the previous owners used to use, and I would like to lower it. The pool is 18000 gallons or so, so I don't really want to drain half of it and refill.
    Will evaporation with subsequent refilling eventually do it? Does CYA even evaporate, or does it remain concentrated in the pool? And if it does evaporate, will this take way too long to lower CYA? Any other ideas on lowering CYA? Thanks
    15k gunite pool. Intelliflo VF. Autopilot SWG.
    2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    Re: Lowering CYA
    CYA does not evaporate. I does sometime degrade over the winter months and convert to ammonia, but unpredictably. Should you live in CA, NV or AZ reverse osmosis treatment may be an available option, otherwise you are looking at water replacement.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Lowering CYA
    You can do it gradually, like I did: use pool water to water the lawn then refill the pool with fresh water. That also is how to get rid of excessive Calcium. It takes a loooooong time.
    I've been able to speed it up on the cheap by putting a flexible downspout extension so it goes in the pool. 1" of rain gets me about 3" in the pool. But then you also have to be around to monitor the water level and pump enough out without going so low you start sucking air in the skimmers
