Sta Rite 400k water in the wrong place
ejonn
Feb 12, 2011
4
Hi folks....
Just plumbed in my used heater. Ran water through it for while and all seemed well. After about 10 minutes, water started coming out of the fan intake??? Quite a bit of water.....Call me crazy, but I dont think its supposed to do this. Have I purchased a used pos? Something inside come loose during shipping maybe? Thought I should ask the pros before I go snooping around inside it.
Thanks for any ideas/experience y'all can throw this way.
Thanks guys...I dont think I'll get my money back, it was way too expensive for shipping (more than the heater). However I will be discussing it with the guy I bought it from. Because it ran for so long before it started barfing out the fan, I am guessing that it probably worked when he had it (it supposedly was fine) and hopefully just a silly little seal has let go. I am setting it up as a single heater for separate pool and spa systems, so to just toss out the psychotic plumbing before taking a look inside is just painful.
Great site, by the way, very much enjoying the info throughout.
Well...the canister is full of water, and it appears when i turn on the water that the coils have sprung a leak. POO!..worth fixin? Is it possible to have maybe a radiator shop try and seal it?
hmmm
I guess if the hole is pretty small a radiator shop MIGHT be able to repair it, but I'm not sure. If the hole is bigger, or there are multiple holes, then it's probably a lost cause.
Did you get this off ebay? Is the seller local? My guess is the guy knew it was bad and sold it anyway. Used pool equipment is a Crud shoot and a heater sure enough is. I hope it wasnt too expensive an experience.
Welcome to TFP!!
I certainly sounds like the heat exchanger is shot :evil:
Take a 1/2" wrench and remove the bottommost bolt from the manifold, and watch rust colored water pour out :pukel:
For now, bypass the heater. Replacing the heat exchanger isn't overly difficult (I'll walk you through it, if you want to go that route) - my former boss charged $1300 for us to do it, but you can probably get a new exchanger for ~ 1/2 that price.
Sorry you bought a defective heater :rant: (the person who sold it to you most probably relied on tri-chlor pucks and didn't keep up on his pH)
Let us know how you decide to deal with this :goodjob:
