Results 1 to 7 of 7
Thread: Water temperature and testing
    Oct 2008
    Yuma, AZ
    33
    I have ... (wife dictates) ... to keep my heated pool water temperature at an average of 88 degrees. That means the temperature flucuates between a high of 90 degrees and low of 86 degrees.
    Do these temperatures have any effect on the accuracy of my water test results?
    14,000gal IG Fiberglass pool with 850 gal spill over spa, Whisper Flo 1hp pool pump, Whisper Flo 2hp spa pump, DE filter, Zodiac Clearwater LM3 SWG, "Heat Siphon" Model SX5HP pool/spa heater, a water leveler and a Kreepy Krauly cleaner
    22,553
    Re: Water temperature and testing
    Those temps won't have any effect on the tests you run. How are you testing?
    Guest
    Ditto what Bama said, but at those temps, you are giving bacteria a good foundation for growth! You really need to watch your FC levels...
    Oct 2008
    Yuma, AZ
    33
    Bama,
    Using the TF 100 testkit ... and doing everything TFT teaches me. Got some different test results within short period between tests and got concerned. Thanks ... now know it was the "tester." salp ... Keeping my FC at 5-6 per TFP balance level for fiberglass SWG pool. Is that a good level?
    The correct FC level depends on what your CYA level is. We can't answer without knowing CYA as well. The best thing would be to post a complete set of test results, since there are other possible dependancies as well.
    Oct 2008
    Yuma, AZ
    33
    Jason,
    Today's Test:
    FC - 6
    CC - .5
    TC - 6.5
    pH - 7.5
    TA - 100
    CH - 250
    CYA - 60+
    Salt - 3850
    FC at 6 is a little high, but probably a good idea since CC isn't zero. When CC goes back to zero, you can lower FC down to around 4.
    This is fairly minor, but it would be a good idea to let TA come down to around 70, or perhaps a little lower. There is no need to actively lower TA. It will most likely come down on it's own. Once it comes down, your PH will be a bit more stable.
