Thread: Leak on pump filter?
    Jan 2011
    North Texas
    99
    Please forgive me because I am still getting up to speed on all the technical names for things.
    So I was doing my routine of cleaning out of skimmers, energy filter and pump filter ( the one attached to the motor, I noted it was an emerson, and it was just replaced in Sept.) and because I am a freak ( ok, the energy filter will pop off if I don't get that puppy tight enough and it's kinda hard) I always turn everything back on for a few just to make sure all is good. SO, now, when I turn everything back off, the pump filter ( attached to the motor) spews small amounts of water out in about 3 directions. Just for a moments when the pressure is changing, but still not good.
    2 questions,
    1. is this going to give me grief with the temps dipping below freezing for the next few days ( and sigh, more winter precip, I don't know how you northerners do it!), we do have a freeze guard that keeps the pool running anytime it dips below 35.
    2. Does this mean that maybe the O ring is going bad? Seems a bit soon.
    I have taken the lid off several times to make sure I am getting a seal and tightening it well...still get the same results, the after shut off spew!
    Hope ya'll don't get too tired of me and my incessant questions.
    B
    15,000 gallons, Cartridge Filters, IG,
    JesseJames's Avatar
    Sep 2009
    Florida
    64
    Re: Leak on pump filter?
    I am only guessing, but it sounds like you might need some lubricant-sealant around the rubber seal. I had that issue once and when I placed the lubricant on it everything fit tight with no leaks.
    13K Gal., Plaster, SWG, Intellichlor IC 20, Sta-Rite 1 HP Pump, Sta-Rite PLM 300 Filter, Pentair LED, Solar, Screened Enclosure, Great White, TF-100
    Jan 2011
    North Texas
    99
    This probably seems like a stupid question, but I found a tube of "pool and spa lube", that's what I use right? ( wouldn't want to make the situation worse!)
    And when you say around the rubber seal, it's that little black ring or more the rim where the lid attaches?
    Thanks
    22,553
    The pool & spa lube is what you need. The little black rubber ring is what actually seals it so it's what needs the lube. Be generous!
    JesseJames's Avatar
    Sep 2009
    Florida
    64
    I placed the lubricant around the rubber seal located where the filter cylinder (the thing that holds the filter) fits together. After that my leaks stopped.
    Jan 2011
    North Texas
    99
    Thanks ya'll! As soon as we thaw out again, I will get that taken care of! I appreciate you talking me through it!
