Thread: Fine particles
    Feb 2011
    Roseville, CA
    24
    Fine particles
    Is my cartridge filter supposed to filter silts in the water? I don't think the net on polaris 280 is capturing it.
    I notice some sand like deposits on stairs. When I sweep it with brush, water got cloudy and it dissipated into deep end.
    I am guessing that I am supposed to stirred up often so silts accumulating on stairs will be picked up by the cartridge filter, right? Do I need a separate vacuum to get rid of these?
    Thanks in advance.
    22000G Oblong shape IG pool
    Hayward Cartridge Filter
    Gray Plaster
    Emerson Threaded Energy Efficient Full-Rate 1.5HP
    Booster pump: Polaris PB4-60
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Fine particles
    Yes, you need a vacuum. The filter can only filter what ends up in the skimmer or drain, so if it settles out before it reaches the skimmer, it sits on the bottom.
    Brushing your pool is a good idea anyway.
    Jan 2011
    North Texas
    99
    Re: Fine particles
    I was wondering the same thing. We have a beautiful cedar tree near that pool that we have discovered is a love/hate relationship. Great tree, hate the stupid tiny needles that fall in the pool.
    So, in addition to the polaris, should we brush or vacuum or both? Been trying to figure out if we need to get a pool vac. We did discover the wall whale back when we have algae & I was sweeping the pool everyday...those are GREAT!
    Makes brushing much easier.
    15,000 gallons, Cartridge Filters, IG,
    May 2009
    Dallas, TX
    782
    Re: Fine particles
    Quote Originally Posted by venticoffee
    A sand/silt bag is available for the polaris that works very well. Not sure that is an answer to your question, but it will certainly help.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
