Thread: Flow Switch Pump Shut-off for Aqua Plus
    I have a pool/spa combo system running with an Aqua Plus controller.
    A plumbing failure resulted in the filter pump running dry and severe damage to my system.
    I think I have found the last of my leaks and fixed them, but what I want to know is...
    Can I configure my Aqua plus to shut down in the case of a loss of flow?
    My flow switch for the chlorine generator is working appropriately, but it only interrupts chlorine generation inb the event of no flow.
    Can I program the filter pump itself to shut off?
    Or can I put another flow switch in-line and wire it to the external input of the Aqua Plus controller?
    I am afraid it wont allow the pump to start (because there is no flow before it comes on).
    Thanks
    Nov 2010
    152
    Re: Flow Switch Pump Shut-off for Aqua Plus
    Depending on how your system is installed, you may be able to enable the "flow monitor" in the configuration menu to accomplish this. It will shut the pump down after registering no flow on the flow switch (if installed) after 15 minutes.
    APSP CST Certified
    17k inground concrete; 1.5hp 2 speed Tristar pump, 300sq.ft. Cartridge filter, AquaLogic PS-4 w/ Tcell-15, Navigator suction cleaner.
