Results 1 to 8 of 8
Thread: Installing a light when I replace the liner
    gruney1's Avatar
    Aug 2008
    Dahlonega, Georgia
    19
    I will be installing a new vinyl liner this spring, and I want to add a light to the deep end of my 16 x 32 pool. Is this a DIY job, and what type of light is recommended? I can do basic electrical, but this one scares me. Thanks for any insight.
    Ken
    16'x32' Inground Vinyl Pool
    Hayward C1200 Cartridge Filter
    Hayward 1HP 2 Speed SuperPump
    Dec 2009
    Central Massachusetts
    2,690
    Re: Installing a light when I replace the liner
    Is there an existing light niche already built into the pool wall?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Installing an underwater light in an in-ground pool without an existing niche is more complex that most DIY types will want to tackle, though it is possible. To install an underwater light you need access to both sides of the pool wall. Typically it is very difficult to get access to the outside of the pool wall on an in-ground pool, as it is often underneath the deck. There are also a variety of special electrical wiring rules that apply to underwater lights. Following all of them requires a good understanding of the version of the electrical code in your area. All of that can be figured out. Still, it is a significant project, requiring some time for research and a fair bit of digging, but it is not really difficult in the sense that it doesn't require any special skills that take a while to master.
    gruney1's Avatar
    Aug 2008
    Dahlonega, Georgia
    19
    Quote Originally Posted by bk406
    No existing light niche there, I would have to install it.
    gruney1's Avatar
    Aug 2008
    Dahlonega, Georgia
    19
    Thanks for the info, I am not sure I want to tackle the light project myself. I will get some price quotes before I proceed.
    South Central NJ
    3,192
    As a pro, I would tell you you no thank you. It would require replacing a wall panel if it's available. Is it work the thousands of dollars it would cost to do that? The decking and coping, if replacements are available, would go and possibly require moving supports. That's a LOT of digging.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2007
    Coastalish 'down easter'
    4,160
    Actually, it's not too hard to retro in a light. It's easier if you remove a section of deck for better access, but it can be done by tunneling. You don't need to replace the panel, just cut a hole in it.
    While you could put in a standard niche, it'd be easier to use a nicheless light (like the AquaLuminII).
    Hope this post was a little 'enlightening'
    Luv& Luk
    -Ted
    South Central NJ
    3,192
    I had forgotten about the Aqualumin II. A very reasonable alternative.
    Scott
