Thread: Goldline Aqualogic Controller
    Sep 2007
    New Jersey
    6
    Can anyone tell me which Aqualogic controller I would need for a pool only, not pool and spa. I know the P4 or P8 will work but in the future if I add an additional pump for a waterfall, , can those controllers work two pumps?
    Also, can anyone give advice on which model (p4 or p8) I would need to operate 1-2 pumps, pool light, SWG, heat pump, and possibly landscape lighting?
    14x32 fiberglass
    mas985's Avatar
    Pleasanton, CA
    11,742
    Just count the number of items you want to switch. The P4 and 4 relays while the P8 has eight. You need a relay for each pump, light and maybe the heat pump although that may just be on all of the time and turned on and off with the thermostat control. Adding the landscape light, you are better off with the P8 so you have a bit of room to grow. You will probably find other uses for the extra relays anyway. I have pad light as well which is nice to work there when it is dark.
    Mark
    Aug 2007
    SE Louisiana
    16
    Also on the Aqualogic systems you can use up a relay as a group function. On my system (PS8) I use one relay to control all lights (3 in pool one in spa). My set up is a bit odd one light in pool on one relay, two other lights in pool on another relay and the spa on yet another relay. However, since these are Savi LED lights, I can control all together with the group fucntion to keep everything in sync. I've used up all my relays with the spa, blower, bench jets, deck jets, the lights, polaris, and heat pump. I may be wrong but I think the pump and heater are not part of the additional 4 or 8 relays you can use.
    22x42 Mountain pond vinyl liner w/polymerwalls Custom concrete steps and bench with spa jets
    7' round spa with stepped spillover
    Hayward 1-1/2hp pump and 500lb sand filter
    Pentair booster pump for polaris 280
    Savi 12v LED lights - 3-pool 1-spa (very nice)
    RayPak 8300ti heat pump
    Goldline PS8 contol system (worth every $)w/Aquapod remote (also worth every $)
    Goldline chlorine generator
    Blower for spa jets (a bit overpowered)
    Polaris Deck Jets
    mas985's Avatar
    Pleasanton, CA
    11,742
    The PS8 has eight relays one of those is dedicated to the pump filter and one to the pool lights. The other 6 can be used for anything else including the low speed of a two speed pump (2 speeds require 2 relays).
    There are 8 breaker slots although you can use double breakers to get up to 16.
    There are also 4 valve controls 2 dedicated for the pool and spa and 2 that can be used for anything else.
    You can download the installation manual directly from Hayward at:
    http://www.haywardnet.com/inground/prod ... sIn_Ground
    Also, to save relays, you can group items together on the relay itself so all of the lights could be placed on a single relay but then you would not have individual control.
    Mark
