Results 1 to 11 of 11
Thread: Laminar Fiber light pool jets
    Jan 2011
    Richmond, Texas
    595
    Howdy -
    Now that I got the pool lights replaced, thanks to TFP, I have another question. I have 5 Fiberstars mini fiber optic laminar pool jets. When reading the manual it states they are supposed to go 3 feet up and 5 feet out max. From looking at my picture you can see that they are way above and beyond that. They have a dedicated 1.5 hp Sta - Rite pump. What is the easiest way to get these down to three feet as they don't work the way I imagine they were intended to work. Also I am concerned that the pressure may be too great as one of the five had been glued back together before we bought the house. Will this require buying a smaller pump? If so what size? I have had some friends suggest a ball valve after the pump but I am not sure that will reduce it enough or if that will cause the pump to prematurely die. From the pump to the lights is approximately 30 feet. Any help is greatly appreciated.
    Thanks
    Flippy
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    South Central NJ
    3,192
    Re: Laminar Fiber light pool jets
    Putting a smaller impeller on the pump will do it.
    Do you have a filter for the lams water? Usually, the feed for the lams has a valve that feeds both the lams and a return in the pool.
    Scott
    Owner of - PoolGuyNJ LLC
    Jan 2011
    Richmond, Texas
    595
    PoolGuyNJ -
    Not sure what you mean by filter. I am still a newbie at this, but have learned a lot from this website, so please excuse my ignorance. From what I can tell the pump has one pipe in and one pipe out and it is labeled water feature and has no other valves. If there is a valve it would have to be underground somewhere between the pump and laminars. Also I don't see any other returns going while they are running. So would I need to change to a 3/4 hp impeller? 1/2? It is possible that they had it plumbed differently when it was first built as the pool inspector said it looked to him like things were moved around. Do I need to change the O rings when I replace the impeller? Thanks in advance.
    Thanks
    Flippy
    South Central NJ
    3,192
    There are different Sta-Rite models and they may have different impellers available. We need to know what model.
    Scott
    Jan 2011
    Richmond, Texas
    595
    This is what it says on the motor.
    Sta-Rite
    Max E Pro
    Model K48L2PA105 1.5 HP
    Thanks
    South Central NJ
    3,192
    3/4 HP impeller Part Number C105-238P
    Seal set 37400-0028S or equivalent. There are several makes available at more reasonable prices.
    Scott
    Jan 2011
    Richmond, Texas
    595
    Scott -
    Thanks so much. I will let you know how it turns out.
    Thanks
    Flippy
    Jan 2011
    Richmond, Texas
    595
    I finally got around to changing the impeller however it only cut the flow by about 1/3. I added a ball valve after the pump to cut down on the flow only to find a ball valve for each laminar in the flower bed while pulling out dead plants from the big winter freeze. Anyway here is a updated picture of how everything looks now. I get my last spa pool light for the stairs this week and will finally be done with the pool. Next project is getting the yard back in shape. I am worried I will loose the three queen palms that survived last years big freeze. Thanks to everyone and this web site for helping me get up to speed on the lights and chemicals.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    great looking pool
    South Central NJ
    3,192
    Looks good. Sorry you needed a ball valve to restrict it. Builders know they should put a bleeder return in the pool but scrimp on the few dollars it takes to plumb it for profit. Expect a somewhat shortened motor life than you might have gotten given your usage pattern. Watch the seal set as they will wear a bit faster too.
    Scott
    Jan 2011
    Richmond, Texas
    595
    Thanks Scott. I appreciate your help.
