Results 1 to 8 of 8
Thread: Calcium Hardness Can I use this to Save $$$
    Can you just get the Ice melt "calcium chloride" at home depot? It would save me a lot of $$$. I found the MSDS sheet for the the stuff home depot sells and it was 65% calcium chloride would that be ok???
    Thanks Mike
    Edit done to post
    gunnite bottom and fiberglass walls that have been coated with epoxy paint. Approx. 24000 gallons, sand filter.
    May 2009
    Dallas, TX
    785
    Re: Calcium Hardness Can I use this to Save $$$
    CH - Calcium Hardness
    Calcium hardness can be raised with calcium chloride or calcium chloride dihydrate. They are available in some areas as Peladow, Dowflake, Tetra Flake, or Tetra 94, often sold as a deicer by hardware stores, and some big box stores, in colder climates. Pool stores will carry either calcium chloride or calcium chloride dihydrate under a variety of names, including Hardness Plus, Balance Pak 300, Calcium Hardness Increaser, etc. Calcium products should be spread across the surface of the deep end of the pool.
    This quote was copied directly from Pool School under the Recommended Pool Chemicals section.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Mar 2007
    San Rafael, CA USA
    12,082
    Note that "calcium carbonate" is NOT the same as "calcium chloride". Calcium carbonate would not only increase the CH, but also the pH and TA by huge amounts so no, you can't use that for raising CH. You can, however, use calcium chloride which is a much more common form of ice salt as noted in the above posting from the Pool School.
    Ok this is what my Homedepot sells. What do you think. Is is safe to use in my pool this summer? The MSDS show 60-100% calcium chloride
    It 60-100 % the same grade as the pool store sells?
    Link to PDF http://www.nasalt.com/images/stories/PD ... s-2010.pdf
    Thanks Mike
    Mar 2007
    San Rafael, CA USA
    12,082
    That MSDS is very poor since it gives such a wide range of concentration, doesn't list the pH, etc. For comparison, Peladow is 90% Calcium Chloride (anhydrous) while Dowflake is 96% Calcium Chloride Dihydrate (equivalent to 72% Calcium Chloride Anhydrous). If the "other" ingredients are just water or sodium chloride salt, then that's OK, but I can't tell that from the MSDS.
    Quote Originally Posted by chem geek
    So should I keep looking or do you think is safe try? Maybe I should look at lowes or Menards to see if they sell something else that has a more detailed MSDS.
    Thanks Mike
    Dec 2009
    Central Massachusetts
    2,690
    Find some peladow or dowflake. Not sure if your area has it. I use it for icemelt. 50 pounds is around $20 here in Massachusetts.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    My local Ace Hardware/Lumber Yard carries Peladow/dowflake and like BK mentioned is about $20 for the 50lb bag.
