Thread: First numbers with new TF kit
    Aug 2007
    Athens, AL
    42
    Hey just got my kit and was amazed at how well it is laid out and how easy it is to use because of the directions. Well here goes. Also, Im hoping that this does not multiple post. Duraliegh told me how to fix that, but I forgot.
    Here are the numbers:
    FC 7.5
    CC 0.0
    TC 7.5
    pH 7.5
    T/A 120
    CH 230
    CYA 80
    Temp 82 degrees
    Thanks in advance for the help I am about to receive
    Tony
    ______
    My Pool set up:
    28,000 gal, 40x32x16 True "L" IGP, 3-8.5 ft depth, Hayward 1.5hp Super Pump, Pro Seriews 300# sand filter, 2 skimmers, 3 returns, Barracuda III suction cleaner
    Those numbers look good.
    I would probably bring the TA down a little, unless you are using trichlor sticks/tablets/pucks, but there is no rush on that.
    30,414
    Re: First numbers with new TF kit
    Valkyrie,
    Wow! Nice numbers and apparent nice work on the accuracy of your first set of tests. I think I asked you before but I'll do so again....How does your water look? My bet is it's crystal clear.
    As Jason said, you might want to get your CYA down a little but it should do it by itself this winter with rainwater, etc. 30 - 50 seems to work well for most folks without an SWG. Temp - 82....perfect for swimming IMHO....your making our Canadian friends very jealous.
    Thank you for the nice comment on the kit.
    Aug 2007
    Athens, AL
    42
    Yes, I forgot to mention that the water is crystal clear!!!
    Tony
    ______
    My Pool set up:
    Aug 2007
    Athens, AL
    42
    I hope its not beginners luck
    Is CC suposed to be zero? And how do I maintain this. I have been adding bleach and muriatic acid as per duraleigh's instructions.
    This place is great!!
    Tony
    ______
    My Pool set up:
    Mar 2007
    Ontario, Canada
    294
    Yes! If your CC = 0 then your pool has achieved ZEN.
    FC = free chlorine (unused chlorine)
    CC = Combined chlorine (used chlorine that has killed some nasties)
    TC = Total Chlorine (FC+CC=TC)
    anything up to 0.5 CC is ok, as long as your pool is clear.
