Results 1 to 16 of 16
Thread: freediverca's pool....
    Sep 2007
    California
    13
    Here are the finished gunite photos. Will be meeting with the stone masons on Wednesday to determine the finished look of the pool.
    Jeff
    Main entry
    Hot tub and main entry
    Hot tub, bench and part of main entry
    Finally built! 30 x 29 inground gunite w attached hot tub, diving rock and spring.
    Color - Satin Matrix Midnight Sea
    Perimeter 90 ft, depth 4.5 to 8.5
    water surface area 569
    Jandy 580 2HP Stealth
    400k Laar LT heater
    280 Polaris
    Aquapure 1400 SWCG
    PDA PS8
    It looks like you are making good progress.
    Sep 2007
    California
    13
    Masonry beginning....
    Spoke with the masons and they are right on track with me. They got started on Friday here is the beginning of the masonry phase:
    Water line rock masonry:
    Another view:
    400k Laar LT heater
    280 Polaris
    Aquapure 1400 SWCG
    PDA PS8
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I don't know that I've ever seen the waterline tile done that way. That's going to look really nice!
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    I really like that waterline tile. Does anyone know if you could use that kind of stone on a fiberglass pool? Thanks
    Sep 2007
    California
    13
    Halfway through masonry....
    Had one small problem so far; the dive rock they put in isn't quite what we discussed, but they will be taking care of that today or tomorrow. And honestly if that is my only problem things are going perfect.
    Main entry after masonry:
    Entire pool site - not all the stone is set yet but the layout is basically finished.
    Closer view of masonry around hot tub and spring is partially rocked in.
    400k Laar LT heater
    280 Polaris
    Aquapure 1400 SWCG
    PDA PS8
    ktdave's Avatar
    Katy, TX
    888
    Re: Halfway through masonry....
    Quote Originally Posted by freediverca
    I'll say!
    Everything looks great, keep the pics coming!
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    sammm's Avatar
    North Richland Hills, TX
    257
    Love the natural stone look. Very nice! 8)
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    Arizona
    924
    Nice! Interesting step entryways.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    wardsntx's Avatar
    Jun 2007
    Spring, Texas
    223
    looking great....love the stone work
    Jay
    36' x19' Freeform, 16' waterfall w/ groto and slide, 5' x 10' sundeck, 12" raised spa. Pentair IntelliTouch, Pentair IntelliFlo 4 x 160, Master Temp 400, IntelliChlor Chlorine generator, Aqua Blue PebbleSheen
    Sep 2007
    California
    13
    Pool is done....
    Well the third time in my case was the charm. Masons came out the second time and didn't really get it still, had to take a day off for the third try to get it right. But here it is one photo of filling the other two are a full pool. I did take some other photos along the way if anyone wants to see something specifically let me know and I'll post it or take a photo for you.
    Filling up...
    Pool filled....
    Another view of the full pool....
    Pictures aren't great I took them as the sun was rising, I'll try to get some others in full day light soon. Also a side note the Wetedge Satin Midnight Sea is amazing. It looks like a black sand beach, the pieces of abalone shell really make it pop in the sunlight. I'll try to get some pics of that as well.
    Jeff
    400k Laar LT heater
    280 Polaris
    Aquapure 1400 SWCG
    PDA PS8
    lovely! I really like the waterline, and the big stone in your main entry!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Sep 2007
    California
    13
    more photos in better day light...
    Here is the deep end:
    Main entry:
    This is the wetedge midnight sea up close through about 6-8 inches of water:
    Bench and hottub:
    From the main entry to the deep end:
    400k Laar LT heater
    280 Polaris
    Aquapure 1400 SWCG
    PDA PS8
    Sep 2007
    Arizona
    36
    Beautiful! I love your water color.
    under construction (o/b): IG 34'x18' free form gunite pool w/ 9' raised spa w/ rock waterfall into pool, 18" raised bond, grotto,baja shelf, 3'-8', turbo twister slide.
    equipment: 2 hp whisperflow, 1.5 hp whisperflow, clean & clear 520 cartridge filter, 400K btu heater, easy touch 8 automation, intellchlor swcg
    ktdave's Avatar
    Katy, TX
    888
    That close-up of your pebble finish looks exactly like mine....GOOD CHOICE . That must be their equivalent to PebbleTec midnight blue.
    LOOKS GREAT!
    Pool School
    TF Test Kits
    Sep 2007
    Midwest
    330
    I really like the boulder "in" the deep end. It gives the pool some dimension that isn't usually created.
    Looks great! Congrats.
    Dave
    Our pool-
    20x40 Free Form Gunite (3'-8'), 26,000 G, AutoPilot Salt Chlorine Generator SC-48, Aqua blue pebble sheen, Textured Sundek, Pentair Easy touch with remote control, 1hp Sta-Rite Max-E-Pro pump, Max-E- Therm heater 333k BTU, System 3 Mod Media Cartridge filter, and Polaris 380 cleaner with booster pump
