Page 1 of 4 1234 LastLast
Results 1 to 20 of 72
Thread: Backyard build in Central Texas, POOL IS UP!!!
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Good afternoon everyone,
    Just like to start out by saying that this forum has been an absolute lifesaver when it has come to the care of our pool I put up last summer. The BBB method is awsome.
    This thread is going to cover my backyard build as I change it from boring to awsome.
    Last summer I bought our first pool. It was an Intex 16' x 48" Round ultra frame. It worked out very well and once I found this site and upgraded the terrible pump/filter that came with the pool I had SPARKALLYPOOLITIS!!!!!
    Well this year the family and I decided we need a bigger pool so I bought the 24' x 52" Intex Round ultra frame to replace the 16' x 48". Below are some pictures of the pool we had last summer with some modification I did to the plumbing and skimmer.
    When it rains the ground gets so muddy next to the patio that you can't even step into the backyard. Late last summer I started to build a pergola and deck off of the back patio. I have never built anything like this before to this scale. I have not finished this project yet because it started to get to cold here. Below are some pictures of this project. Once the weather starts to get warmer i will be finishing the deck and start to work on the new pool area.
    I will be updateing this thread as my build progresses.
    Thanks.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Re: Backyard build in Central Texas
    Congrats from a fellow Central Tx person Mark
    Pool and atrium look WONDERFUL
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Feb 2008
    Denton, TX
    5,061
    Great looking pool.
    crookm11's Avatar
    Jun 2010
    422
    OK everyone,
    Here is the start of my upgrade. I have taken down the pool and started my prject. The picture below shows the sand pad I made for the 16' x 48" round pool. The size of the sand pad was 18' round. You can see the size difference between the 16' and the frame work setup for the 24' pool. Before the sand was layed down, I killed the grass and put down a weed blocker. I have started to kill the grass out to the orange painted line and will be adding more weed blocker before I put down more sand. I will be building a ground level wooden deck around the pool to keep the side poles from pushing out to far as the weight of the water is pressed on the sides of the pool. You will be able to walk around the pool on the deck on help keep the grass and dirt out of the pool.
    Stay tuned for more.
    Mark Crook
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    looks good
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    So..........For 2012 the plan is to knock down the fence and annex the neighbor's backyard to go Olympic size then! Nice deck.
    crookm11's Avatar
    Jun 2010
    422
    Quote Originally Posted by woodyp
    Thanks for the comment on the deck.
    Actually the plan is to get one of those Margaritaville frozen concoction makers!!!
    Mark Crook
    crookm11's Avatar
    Jun 2010
    422
    I have started to plan out the plumbing for the pool. The pool will be all hard plumbed. I really hate the hoses. No matter how you set them up they just look horrible. Last night I started to plumb the pump to the sand filter. I have seen so many nice pool equipment pads on this site and thought to myself I can make my above ground set up look just like inground set ups. One thing I have noticed on many pads is the addition of water spigets added to the set up. Not sure exactly what they could be used for but if they are put in by pros then there must be a reason. (Will need to find out later) so i decided to add 1 to mine. With the help of the various sites and this one I have figured out how to add standard PVC pipe the NON standard set up Intex uses. I will explain the process I used. As everyone know that owns an Intex pool is the fact that the threads used are not standard so NO standard threaded pipe fitting will directly connect to the Intex equipment.
    1. Intex has an adapter part number 10849. The adapter has 2 sections of different sizes so different size hoses can be connected. The section I used for the connection is the middle section.
    2. I cut off the smaller section and used a Dremal to open up the opening to allow more water flow. The middle section will alow a 1.5" ID hose to connect to it. I used 1.5" ID braided PVC hose from Lowes about 4" long.
    3. The next item used for my adaptation is a short piece of 1.25" PVC pipe about 3' long. Once I put the hose on the adapter used a pan full of boiling water to heat up the other end of the hose to allow the 1.25" pvc pipe to slide in the other end of the hose. You could just try and force the pipe in the hose but heating up the hose is much easier.
    4. Now that I have the Intex adapter connected to the 1.25" PVC pipe useing the braided PVC hose I used 2 pipe clamps the secure the connection.
    The next item used is a 1.25" to 1.5" slip bushing. The bushing allows me to use 1.5" PVC pipe through out the process. The only spots in my plumbing that will not be 1.5" is at the adapters.
    I made the same adapter for both ends of my plumbing.
    I will not have to use any unions because the way that Intex has set up there equipment the adapters thread onto the eqipment like unions.
    Check out the pictures below.
    I will continue to add the this thread as my progress contiues.
    Mark Crook
    crookm11's Avatar
    Jun 2010
    422
    Deck around an Intex 24' pool
    OK,
    I have started on my deck around my pool. The Intex 24' x 52" has 24 sideds. I calculated the angles and lenght of all the sides used to create the trapazoid that makes up just one side of the pool. The deck will consist of 24 trapazoids connected together. Each trapazoid will have 4, 2" x 6" x 12" pounded into the ground and mounted to the inside of the trapazoid for support. check out the pictures below.
    I will continue updating as progress is made.
    Mark Crook
    crookm11's Avatar
    Jun 2010
    422
    Hi everyone,
    Now that the kids have started soccer the progress has been a little slow. I have finished all of the 24 individual sections around the pool and started the equipment pad. I still have some more braceing to do on the equipment pad. The wind blows to that side of the yard so the skimmer will work great at that location. Before I start to lay the decking down I need to finish the foundation for the pool. The deck around the pool is level but the ground is not so there are a few gaps between the ground and a few sections of the deck. My house sits on the lowest lot in our subdivision and I get all of the water runoff from the neighboring lots. I will be adding some backing boards in the sections that have the gaps to help hold the sand in place from the rageing river that runs through my backyard when it rains. More weed barrier will be added and then more sand. While the sand is being added I will be wetting and compacting the sand to form a nice strong level base. The level of the sand will be about 4" from the top of the 2" x 6" used for the framing of the deck. Regular level, line level and a laser level was used to build the deck so the pool will be level once it is setup. I shound not have any issues.
    A few pictures of the progress.
    Enjoy!!
    Mark Crook
    crookm11's Avatar
    Jun 2010
    422
    Hi everyone,
    I have made some more progress on my backyard. Below are some more pictures of the build. I will post a little bit about each picture.
    First section of decking installed.
    SAM the building inspector.
    In each of the 24 sections the grass will be killed and mulch will be added under the decking.
    A few sections completed and the equipment pad.
    The equipment pad.
    View from back corner of yard.
    The rest of the decking material ready to be installed.
    Finished the deck.
    Another view.
    Equipment pad.
    I will post more as the project progresses.
    Mark Crook
    crookm11's Avatar
    Jun 2010
    422
    Re: Backyard build in Central Texas, POOL IS UP!!!
    Hi everyone.
    I was busy this weekend.
    I GOT THE POOL UP!!!
    Below are some pictures of the pool and plumbing.
    Now its time for the electrical.
    Will post more.
    Enjoy
    Mark Crook
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Nice work
    Great looking Pergola! Did you free build it, find some plans, or buy a kit? We are looking to add one or something like one to our new deck.
    Pool #1 IG 24k Diamond Brite plaster with spill-over spa. Jandy Aqua Link RS One Touch with built into pool floor cleaner. Jacuzzi Magnum pump/basket feeding Hayward top mount Zeosand filter. Jacuzzi Magnum pump/basket for Spa Jets. Heat Siphon pool heat pump. Dolphin Robotic pool cleaner.
    Pool #2 IG 35K 20X40 Vinyl. Hayward top mount Zeosand filter with Pentair 3 HP IntelliFlo VS+SVRS. Chemical Free pool using Water Doctor Copper Ion Generator, PoolSkim, Polaris 9300 Sport robotic pool cleaner, Heat Siphon pool heat pump, solar blanket, Ameri-Dome 50X30 dome enclosure during Winter.
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    excellent mark! i knew it would be great looking. fantastic work!
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    crookm11's Avatar
    Jun 2010
    422
    Quote Originally Posted by iPhone
    Thanks for the comment. the Pergola and deck was a free build, No plans. The Pergola is 16' x 14' and the whole deck is 28' x 16'.
    Mark Crook
    crookm11's Avatar
    Jun 2010
    422
    Quote Originally Posted by jsf0656
    Thanks for the comment. How did your deck and slide hold out during this last winter? I bet the G-kids are waiting for the pool to open and hit the slide. I will be adding a deck that will be level with the top of the pool and I will be stealing your idea of the slide.
    Mark Crook
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    the deck and slide held up fine over the winter even though we had some pretty cold weather at times. BTW, i'm hoping to steal a few ideas from you as well like the skimmer and the original plumbing that you did. also i liked the way you made the flower border around the bottom of the pool with the sand. it looked really good! its great to share ideas with everyone!
    JoshU's Avatar
    New Orleans, LA
    543
    Nice installation.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
  20. Back To Top    #20
    Fantastic install. I am very interested in how you determined the size of each trapazoid section of deck to make a circle around the pool. Thanks!
    Sharkline Dolphin AGP 24" x 54" Millennium cartridge filter Millennium 2-way 2HP-3/4HP pump
