- Jan 27, 2011
- 2
I recently discovered a leak in the brass valve of my auto filler ( the float valve type like in a toilet tank), it would leak ( spraying a fine mist strait up from the top of the brass valve) only when the valve was open and the water was filling. Called my pool guy who came to replace the valve and when he removed it found the pvc pipe it was screwed into was stripped. This all occurred after a hard freeze I dont know if that caused it or if he accidently stripped it but thats where I am now. It was not leaking from that point before I checked it closely when I noticed the leak. He's not sure what to do now Im not sure I trust him now. Any suggestions on how to proceed with repair.
thanks , chris
thanks , chris
