Thread: auto filler
    auto filler
    I recently discovered a leak in the brass valve of my auto filler ( the float valve type like in a toilet tank), it would leak ( spraying a fine mist strait up from the top of the brass valve) only when the valve was open and the water was filling. Called my pool guy who came to replace the valve and when he removed it found the pvc pipe it was screwed into was stripped. This all occurred after a hard freeze I dont know if that caused it or if he accidently stripped it but thats where I am now. It was not leaking from that point before I checked it closely when I noticed the leak. He's not sure what to do now Im not sure I trust him now. Any suggestions on how to proceed with repair.
    thanks , chris
    Hans Deters
    Vinyl inground pool. 20 x 50. Pentair 3hp Intelliflo pump @ 1600 rpm. Aprox 45,000 gal. Coverstar cover. Salt generator. Sand filter. Built July 2008.
    22,542
    Re: auto filler
    If you can post a picture of it we might be able to give some advice.
    Re: auto filler
    having technical difficulties with picture, but the filler valve attaches to the side of the bucket. It seems the part the filler valve screws into is a molded part attached to the bucket that sticks out about a quarter to half an inch. The fresh water in line must be attacked to this somewhere under the pool decking. I assume when they were trying to put on the new valve they cross threaded it and striped the threads as it was not leaking from this connection before. The female receptor on the bucket is 3/4 inch I have had one proposal to "fix" it by boring it out to 1 inch, rethreading it and using a valve with 1 inch coupler which will thin the female receptor quite a bit. My concern is that if its too thin it may fail under the force of the fresh water pressure. I suspect to do it right I'll have to bust out some of the decking around the filler bucket cut the line in and out of the bucket, and put on a new bucket with good threads and reconnect it and re deck it. Just looking for opinions/options before I go to that expense.
    thanks, chris
    Hans Deters
    South Central NJ
    3,192
    Re: auto filler
    What make is the autofiller?
    Scott
    Owner of - PoolGuyNJ LLC
