For a month in the spring and fall I think we can live with a extra $200 month to use the pool.
"so unless you are one of these people, then I wouldn't bother" Wouldn't bother with what?
mas985 said:mschmidt33 said:Since I have never owned a pool I'm not too sure... I believe at this time the only time we will use the gas heater is to keep the pool warm in the spring and fall when solar is not effective enough to keep the pool at the temp we want.
As the temperature cools off, it will be more difficult to keep the pool warm. Even with a solar cover, the pool will lose 3-4 degrees at night which will require about 500k to 700k BTU or 5-7 therms. Twice that without a cover. If you are paying $1/therm, that is $5-$7 per day, $150-$210 per month, to keep the pool heated. Is that something you can live with?
Except for the diehards, most people are not too interested in swimming when the air temperature gets much below 75 degrees, so unless you are one of these people, then I wouldn't bother. To extend the swim season, go with as many panels as you can fit on your roof. This will end up being much less expensive than gas.
