Results 1 to 17 of 17
Thread: Pool cleaner recommendations?
    I'm looking to save some time on my weekly pool cleaning task (I currently do it manually). What I determined so far, is that I would probably want one that is powered by the pool pump. I don't have a whole lot of debris on my pool floor (mainly some leaves). It also doesn't matter too much if the cleaning is slow; I would just drop the cleaner in the pool about once a week. My pool is medium sized at roughly 16000 gallons and gradually drops off from 3 feet to about 8 feet, so the cleaner should be able to climb that hill. I also want it to be gentle on the plaster since I just replastered the pool last summer and don't want to do that again any time soon.
    Any suggestions on what to get?
    Thanks so much!!
    Guest
    Re: Pool cleaner recommendations?
    The Pool Cleaner is one of the better suction side cleaners
    www.thepoolcleaner.com
    Thanks so much for that link!! Any idea what the price range roughly is? I don't think I saw it mentioned anywhere?
    Quote Originally Posted by salp
    http://www.thepoolcleaner.com
    SW Georgia
    300
    Just bought a 4 wheel suction cleaner for around $550 from Pool Plaza. I had to purchase the tires for a vinyl pool for $100 the unit comes with tires for concrete/plaster. I have not received it yet, once I do I will try to repost and let you know how it works.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Guest
    Quote Originally Posted by jasonknox
    Why would you have to spend $100.00 more for vinyl when all you have to do is specify what surface you have... There is no up charge for that.
    SW Georgia
    300
    I guess they got me Sal. They did not indicated that I had the option to request that. Shame on them.
    I called pool plaza and asked why they did not sell me a unit with the proper tires and they indicated that they did not know that they had a choice. That is scary. I pointed them to another website that does give you a choice and pointed out that if I did not get a credit for the tires I bought I would be returning the unit as soon as I received it. They have agreed to credit my account but I do not think that I will use the unit until I see the credit. What a hassle. I really have a low tolerance for companies that do not train employees in the products that they sell.
    Thanks Sal!
    Looking forward to your review
    SW Georgia
    300
    I received and installed my cleaner (The Poolcleaner 4wheel suction) and let it run over night. I woke up to a sparkling clean pool. It even picked up the leaves that were being drawn in by the main drain. As of two days in I am very pleased with my purchase.
    Guest
    Did you get your $100.00 back???
    SW Georgia
    300
    I sure did. Thanks
    Guest
    Nice
    Thanks Sal!
    Just doing my due diligence here while looking for a pool cleaner. I don't see an option anywhere for the at the pool plaza. Can you point me to that site where it is?
    22,000 In-Ground Vinyl Fox Pool
    250,000 MiniMax Pentair natural gas heater
    4 returns 1 skimmer 1 main drain
    1hp Hayward Max Flow II single speed
    Sand fox pool Filter
    First year owner of the aforementioned.
    susa's Avatar
    Oct 2010
    Deep South
    578
    sounds overpriced, see this
    Guest
    Quote Originally Posted by mrpunchy
    Thanks Sal!
    You probably need to call them, it is a special order, so it might take a couple extra days, but it should be the same price.
    You should not pay any increase for differenct pool surfaces...
    SW Georgia
    300
    Thanks Sal!
    For the life of me I can not find the website that asked what type of pool surface you had during the ordering process of the cleaner. I will keep looking and let you know.
    I recently bought the 4-wheel model. Works great! When there are a lot of leaves, I still have to clean those up manually but that's not too big of a deal. Works well overall!
