Thread: Help with Paramount PCC 2000
    I have just recently purchased a home which has a pool equipped with a Paramount PCC 2000 infloor system (I have never owned one before). Unfortunately the system is not operating and I am in need of some assistance and was hoping someone could possibly help or steer me in the right direction to get some help. I have tried to research as much information online that I can seem to find on the system but have not found anything that describes what’s going on with my equipment?
    My system appears to have a dedicated pump for the infloor system (I have two pumps the other is operates the filtration system). However the heads do not function when the pump is turned on. I have removed the valve shell and module. The module appears to be okay by visual inspection however the valve shell seems to have a couple possible issues. The switch on the shell that operates pause/run function appears to be broke. The other issue that seems a bit odd is the shell is missing a pressure gauge (it’s not missing…there is no connection/spot for one)? The valve base has 6 ports and all are open. The pool is approximately 17,000-20,000 gallons. There are a total of 13 heads, 4 on the stairs 4 in the shallow end, 4 in the deep end and 1 on a shelf. When the pump is turned on all heads remain down and do not function. The only head that appears to do anything whatsoever is the single head on the shelf by the deep end which bubbles air and water only (the head remains down while doing this).
    Is there any advice on what might be causing this or what other things I can do to check the system? I do know that the pool was emptied for a period of time so not sure if this would cause any issues? I would appreciate any help anyone could provide.
    Thank you,
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    Re: Help with Paramount PCC 2000
    Maybe this will help you troubleshoot some.
    http://www.1paramount.com/blog/2010/04/ ... eshooting/
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    Thanks carlos I'll check this out!
    South Central NJ
    3,192
    Is the gear box in the dome? If not, you need one. The system is supposed to pop but a few heads at a time.
    Scott
    Owner of - PoolGuyNJ LLC
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Not all systems have pressure gauges, so don't worry about that. If you post some pictures, that would help. From how you described it, it sounds like you're missing the gearbox part that controls which zones are on.
