Thread: Raypack PC Conrol board - how to determine if it is bad?
    I have a 3 year-old Raypack R266A propane heater. Just now getting getting the ILO error code. The pilot light fires, but the burner will not. Power cycling the heater does not fix the problem.
    How can I determine if the problem is with the pc board, the gas control, or the transformer?
    Thanks.
    IG 15k gal rectangular plaster(?), 650 gal attached spa with cascade to pool, single filter pump, DE Filter, booster pump w/Hayward Phantom, Jandy Aqualink RS 4
    Oct 2010
    Georgia
    317
    Re: Raypack PC Conrol board - how to determine if it is bad?
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    You get an ILO when the heater tries to fire three times with no ignition. The heater is giving you a code, so we know the X-former is working, if it weren't, you wouldn't get a display. The fact that it is a ignition lock out tells us the board tried to fire, so it's (probably) not that. The last thing left is signal, or power to the gas valve. If you get voltage (at the valve), it's the gas valve, if not, it's the board,
    or...
    One other thing the manual does not tell you is the pilot may not be giving flame rectification, which is nessesary for main burner fire. When the pilot lights, do you continue to hear the buzz of the electronic ignition at the pilot? If so, you may have some soot or mis-alignment of the flame rectifier, this will prevent voltage to the gas valve. Check voltage to the gas valve first (easier things first). Then, if you think it may be soot, gently tap the pilot with a screwdriver handle, that will most of the time dislodge any soot. If you continue to hear a buzz buzz buzz. then you may need to either check rectifier gap, which involves taking the pilot assembly out, or call a pro.
    Good Luck
    Factory Warranty Station for:
    donaldm823's Avatar
    Cape Coral, FL
    147
    Quote Originally Posted by Pool Clown
    or...
    Good Luck
    I had to buy a Raypak control board last year after getting a clock failure code with no clock installed. The part is available from http://www.poolysupplyworld.com, Item Name – Item Name – PC BOARD, RP2100 CURRENT - 010253F
    Quantity Ordered – 1
    SKU Number – 010253F
    and it was an easy install and comes with instructions. Less than 30 min and replaces one for one with 4 screws and no new wiring. I looked around and this source was the cheapest and was an OEM part
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
