Results 1 to 20 of 20
Thread: Onga (Pentair) Silentflo or Jandy ePump?
    Jan 2011
    Australia
    116
    Here in Australia there is very little choice other than single speed pumps.
    ie:
    Astral Viron P300 3 speed pump about $700 (slowest speed isnt very slow: 1420rpm) http://www.hurlcon.com.au/sites/default ... %20WEB.pdf
    @1420rpm 1.5amps 200 litres p/m @3.6metres head (I presume that there would be a fairly sharp drop off in lpm with increased head hence calc@3.6m).
    @2800rpm 6.7amps 302 litres p/m @8metres head
    Pentair Intelliflo $ 2000
    Zodiac have just announced the introduction of the Zodiac FloPro ePump in Australia.
    The rrp will be around $1600 including the basic controller. (although may be less in the hands of the retailers).
    Due to the power supply differences, it will have a top rpm of 2830 and minimum of 600 and I guess it will be the 1.5hp
    http://www.jandy.com/ePumpPdf/SL5171.pdf
    Onga (Pentair) Silentflo SF750 1hp $460 (http://www.onga.com.au/objectlibrary/62 ... omance.pdf)
    @2800rpm 3amps 250 litres p/m @8 metres head
    Comparing the Viron with the Onga, the Viron at 1420 rpm and depending on the head (say 5/6m for both pumps) it would move about half the water using half the power consumption of the Onga, therefore the running cost would be the same to move the same amount of water. HOWEVER at 2800rpm the Viron would use more than double the power usage of the Onga, when using the vacuum etc PLUS it's $250 more to buy.
    11k gallon IG Ferrocement , Onga (Pentair) SF750 1hp pump, Onga Pantera MK11 PCF200sqft Cartridge Filter, Watermaid WM40-QT300 SWG, Spa Electrics GK7 LED
    South Central NJ
    3,192
    Re: Onga (Pentair) Silentflo or Jandy ePump?
    E-Pumps come in two different power ratings, 1.5 and 2 HP.
    Without telling us the sizes of your options, we can't tell you which way to go.
    Scott
    Owner of - PoolGuyNJ LLC
    Jan 2011
    Australia
    116
    I dont think Zodiac have announced that yet: nothing on their site or in the leaflet I read.
    I imagine they will be offering the 1.5 rather than just the 2 which I would think would be too big for my pool (although with 8 settings I dont suppose
    it matters that much providing they can be set as low as each other).
    susa's Avatar
    Oct 2010
    Deep South
    578
    I would be very interested in the Blue Eco and will check out importing one next time one of the family pools needs a replacement, especially due to the DC (vs AC) design as all my new electric systems use DC compressors, blowers and controllers.
    Jan 2011
    Australia
    116
    I cant find a website for them or any spec for the pumps, which is a bit worrying.
    If the pump goes wrong it could take a very long time and a lot of money to send it to the Netherlands and back. Plus you guys are on a different system to Holland which I think is 230v 50Hz.
    PS: the Viron P300 uses a DC motor and is available in the US
    susa's Avatar
    Oct 2010
    Deep South
    578
    most stuff I buy from EU is 220-240v and dual 50/60hZ, works fine here.
    every piece of my pool equipment runs on 240v supply
    Jan 2011
    Australia
    116
    Have been advised that as my power supply is erratic, any pump with electronics isnt going to last very long with voltage
    surges and frequent sudden outages. Looks like it will need to be the Onga. Wondering now how long a chlorinator controller will last....
    22,549
    If you live in an area with power problems the best thing you can do for yourself is get a whole house power conditioner/regulator. That'll save a lot more than an electronic pump controller.
    Quote Originally Posted by pool250
    This is interesting - so your conclusions are that the Onga will be more efficent ie use less electricity than the Viron - since at 1420 rpm it will cost the same amount to move the same amount of water, but at 2800rpm - the Viron will cost more to move the same amount of water that the Onga. Are you certain of this? If so - the choice is easy - why would anyone buy an Viron?
    Kind regards,
    Mil
    Mar 2011
    441
    HOLY POOP!
    They VFD pump you poor souls get from pentair is based off the dynsglass pump design.
    First your toilet spin backwards now this.
    I feel bad for you guys down there.
    20X40 30,000 gallon gunite pool
    Jan 2011
    Australia
    116
    Quote Originally Posted by racket
    HOLY POOP!
    compared to all the of the other single speed pumps I have looked at down here, the SF750 is quieter and more efficient than any of the others by far.
    3amps draw for a 1hp pump is very low....unless I am missing something??
    Edit the single speed is from Pentair, the 3 speed from Hurlcon; I think you mean the Hurlcon?
    PS: my flush is syphonic and goes straight down, not round and round so please don't feel too bad, plus we also have Christmas in mid summer!
    Jan 2011
    Australia
    116
    Quote Originally Posted by mil
    Kind regards,
    Mil
    yes, I'm sure. Whilst they dont actually publish the figures (which is probably why people buy it), they gave them to me on the phone. Its also louder at 2800rpm than the single speed.
    Jul 2010
    Auckland, NZ
    13
    ie:
    Cheap! The Viron sells in NZ about $1600 + GST ($1347 USD), the Intelliflo VS has a retail price of between $3500 - $4,000 NZD depending on the supplier.
    You should start to see similar pumps to the Viron over the next year, Speck have a pump which is the same motor with a different wet end.
    Jan 2011
    Australia
    116
    Quote Originally Posted by Jimmy_from_NZ
    ie:
    Yer, I know. Whenever I feel like weeping at how much more we pay for things here than in the US, I always console myself in the knowledge that it could be worse; I could be paying NZ prices
    Mar 2011
    441
    The onga looks like this.
    Which is the dynaglass/dynapro
    With e different motor.
    http://www.pentairpool.com/pool-pro/pro ... ps-204.htm
    Mar 2011
    441
    You could almost pay me to fly with ab intelliflo in my luggage, and break even.
    Jan 2011
    Australia
    116
    None of the dynapro's draw anything near as low as 3amps and as you say it must have a different motor, therefore
    A) can a comparison really be made between the SF750 and the Dynapro and if so why?
    B)If a comparison can be legitimately made, why you no like the dyanpro?
    Mar 2011
    441
    The way is seals, the noise it creates, as well as the diffusers tend to erode easily.
    Jan 2011
    Australia
    116
    Seal between motor and body? this might be different with a different motor?
    I dont think the motor on the SF is noisy according to the spec.
    Diffuser? dont know what they are, is that a motor part which might be different.
    I havent bought the pump yet and Onga was until recently an Australian company, who have a good rep for reliable pumps.
    From what I can see so far, your beef seems to be with the Sta Rite motor not the pump body.
    As the Onga motor is obviously totally different, I am not sure that these two pumps are sufficiently similar for you to condemn the Silentflo on the basis
    of your dislike of the Dynapro.
  20. Back To Top    #20
    Mar 2011
    441
    No my beef is with the sealing mechanism and the distances between the shaft seal plate and bearings. The noise of a pump is cause by both speed, and hydraulics. A whisperflo pump is quieter much quieter than the Dyna* line using the same motor. It has to do w/ the impeller design, and diffuser design.
    That being said the onga will propably serve you fine. It just would have been better based on the whisperflo' body.
