Thread: Pool Cover Gone, Algae Took Over
    poolmomma's Avatar
    Jul 2009
    Southern Virginia
    78
    Virginia got a HUGE winter storm with 14+ inches of snow that took out, not only our deck umbrella, but it put so much wet snow on our pool cover, it ripped and dumped snow and some leaves into the pool. It is now a pit of algae since I have been working so much and haven't had time to assess what needs to be done. I DO know the water is way cold!!!! And there is a ton of algae. Any suggestions on what I should do? I started to run the pump again today but only want to run it about 8-12hrs a day.
    15' RND 48" AGP 5,300 GAL
    16" Sparco Sand filter,I got a new pump in 2010, but not sure what it is
    Successful Convert to BBB and lovin it!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Pool Cover Gone, Algae Took Over
    If the water is not frozen, you could certainly clean it up shock and the winterize again.
    poolmomma's Avatar
    Jul 2009
    Southern Virginia
    78
    No frozen water here...yet. It's supposed to get cold-er this weekend. They say around freezing, but the pool has only really "froze" 1 time and that was when it dipped into the low 20s for about a week. I am going to go ahead and shock the **** out of it and see what I can do. My bot fried on me right at the end of the summer but it's too cold to put on in there anyway. This pool must be built on an indian burial ground...there's even a sink hole dangerously close right under our splash deck! The luck we have had since install has been nil.
