Results 1 to 10 of 10
Thread: Who makes the Best Swivel durable vacuum hose? Poolmaster?
    This is the year of the pool for me and I've basically picked up a whole bunch of stuff that will improve my swimming season when it begins.
    I've purchased one of those really thick and heavy rubber mats sold at Home Depot that you put on your stairs for the winter so you don't slip, I will be placing this under my pump to reduce vibrations in My Cabana since I have a sealed wood floor.
    I Purchased a Skimmer Anegl so I don't have to touch the frogs and dead rodents or any other of the gross stuff I find in my skimmer.
    I purchased a Whale Wale to help with brushing.
    An Extra pole so I have three now and I don't have to watse time removing devices, everything is ready to go.
    A leaf rake with a lip that will be able to pick up little rocks or leaves much easier from the pool floor.
    One of those crazy test kits recommended here along with a magnetic stirrer.
    Still looking for a good Solar Shower
    Still looking for a heavy duty towel rack for several towels
    Still lookingfor something to store my poles and hose on.
    Now I'm on to replacing the Vacuum hose, I want a strong durable Swivel hose, I'm still using that standard white one that came with the pool when we purchased our inground, the really cheap one the pool company gives you. Now can anyoen vouch on the quality difference between the different brands of hose? I'm leaning towards the Poolmaster Swivel hose, it's blue, but I really have no idea how the quality compares to other brands available.
    Does anyone Know?
    18' x 36" Ovalish 80,000 Litre Vinyl IGP. 2 speed 1HP Hayward pump SP2607X102S. 300 Pound Sand Filter. Summit Sum5 Heat Pump, Goldline Controls Aqua Logic P4 System, T-CELL-15 SWG, Aqua Pod Remote Control, Pentair 7845xx02 light.
    TF-100 Test Kit, SpeedStir Stirrer, Pool Chemist in training.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Who makes the Best Swivel durable vacuum hose? Poolmaster?
    There are certainly different quality hoses available. The one that came with my pool is much better quality than the replacement. Sorry I can't advise on which ones are the good ones, but I'll be watching the thread as well.
    Still looking for feedback on hoses, also does anyone know what a swivel hose is? how does it differ from a regular hose?
    22,553
    ON a swivel hose the cuff swivels on the hose so it doesn't twist up when using the vacuum. I have one of both and the swivel is much nicer.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    JoshU's Avatar
    New Orleans, LA
    543
    Haviland Consumer Products makes a very good quality hose. They are US made hoses.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    I just had to replace my hose too. Both ends on the original one given to me by pool company cracked. Yesterday I purchased a 'Pool Style' with swivel head from the local pool store. It is a much higher quality than the original. I love it. The swivel head end is blue the other end is white, so you don't get mixed up on which one goes where.
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    Jun 2007
    New Jersey
    653
    I have always found the swivel head concept to be pretty useless. They don't seem to work at all once the vacuum hose is actually under suction. It is slightly useful after you hook up the skimmer end but before you turn on the suction to get out any kinks. However, I try to hook it up without kinks in the first place.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    This is going to sound dumb I'm sure, but does end that swivel go on the skimmer or on t Vacuum head?
    Quote Originally Posted by Rockstead
    The swivel end goes on the vacuum head. The swivel is not airtight, and if you use it on the vac-plate above water, it will suck in air.
    Support the site
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    Invest in a good quality weighted vac head with swivel and urethane wheels. They cost about $80 for a good one. Then run real smooth over plaster or pebble.
    On the hose check out-- I-Helix brand. Very good quality.
    B
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
