Thread: Should I use the vac in low speed?
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Is there any reason not to use the manual vac with the pump in low speed. It's got plenty of suction with the vac hooked up to one
    skimmer and the other skimmer and the main drain valved off.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    22,551
    Re: Should I use the vac in low speed?
    There's no reason not to. As long as you have good suction it's fine to use low speed.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Cool, thanks!
