Thread: Early Opening in CT? How early
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    420
    I have a inground gunite pool that is heated off my Central Boiler ouutdoor wood furnace. I plan on having a lot of wood to start pumping hot water into the pool - Q- how early can you viably open in New England if you have a good heater running all the time? April ?
    Any feedback or stories would be appreciated. I read the other day it's only 110 days to Spring.
    B
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    South Central NJ
    3,192
    Re: Early Opening in CT? How early
    I'd say no sooner than April. That is pretty much the end of the hard freezes. God forbid a night time ice storm takes out power. The above ground plumbing would be at risk. That plumbing includes the equipment like the heat exchanger, pump, filter....
    Scott
    Owner of - PoolGuyNJ LLC
    Dec 2009
    Central Massachusetts
    2,690
    I'm in central massachusetts and I open around tax day. By then the chance of a hard freeze is over. Thats really all you need to worry about. If it gets down to 28-32, just run the pump. You just dont want low 20's for an extended period.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    420
    I am targeting April 15th or sooner if it thaws out. Do have a propane stand by back up generator.
    ColorQ Pro
    TF-100
