Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: how to control IntelliChlor IC40 w/Current Control Relay
    susa's Avatar
    Oct 2010
    Deep South
    578
    parts needed:
    macromatic cokp01a22 relay and socket 70170-D
    total cost about 90.00
    this enables system to monitor power use of IntelliFlow VF (or any variable speed programmable pump..) and to intelligently switch on/off the SWCG based on power settings (pickup and dropout, measured as a percentage of pickup amperage)
    currently I have relay dialed to turn on IC40 cell at about 120 watts and to power off at 110 watts.
    when I run an all day program at 95 watts, 875 rpm, the relay automatically turns off IC40 and there is no need to depend on the flow switch sensor (which would also turn RED but keep the transformer and the cell powered without a current control relay).
    when system runs a 20 GPM or higher program, the IC40 automatically turns on and measures water salinity and resumes running preset program for chlorine generation.
    pictures show final installation, without the enclosure flip cover (allowing quick adjustments as needed or changes to relay programming).
    Jul 2009
    Northern California
    20
    Re: how to control IntelliChlor IC40 w/Current Control Relay
    Good idea! I need to do this same thing with my EchoStar and Aquapure. Any suggestions on where to get the relay and socket? I checked Granger, but they don't have the specific relay...
    Thanks
    15,000Gal IG Gunite\Color Quartz Plaster
    Jandy CL460 Cart Filter (460sqft, 150GPM)
    Hayward EcoStar SP3400VSP
    AquaPure 1400 SWG
    susa's Avatar
    Oct 2010
    Deep South
    578
    if you go on macromatic web site, there is a link to where to buy which does not matter as they all sell same series and order from same factory.
    I am planning on using a Crouzet (Syrelec) LIRT220A Current controled relay because it is 220 volt, the same as my Intelliflo pump. So the wiring is simpler, no need for 110V power.
    Also plan to add a digital delay timer (B1S-R-220), which resets to whatever preset run time I choose, each time the pump runs. Since I am running the pump once a day for 7 hours, I will set the SWG to run for the first 4 hours. Then simply adjust the SWG run time on the digital timer to maintain the proper chlorine level.
    See attached schematic. SCHEMATIC HAS CHANGED, SWG IS ON NORMAL CLOSED (NC) TERMINAL
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
    susa's Avatar
    Oct 2010
    Deep South
    578
    Having worked in the power industry for some decades and while my Pentair equipment is all 240v, the Current Control Relay is actually simpler to wire as 120v since *all it does* is to monitor the power use and intelligently switch things on or off
    A 120v CCR can monitor and enable/disable 240v devices
    That said, there is never a single solution, use what works
    Quote Originally Posted by susa
    Simpler because the 110 in my location is on a separate breaker and in a different box.
    I was just attempting to add something to your great work, no disrespect.
    Thought maybe someone would like a schematic...
    susa's Avatar
    Oct 2010
    Deep South
    578
    Ok, that sounds good.
    Make sure the device contains a programmable dial to *delay* action in case there are random voltage fluctuations. In my case, I use up to 55-60 second delay to wait before actioning either a turn-On of the IC40 Cell and Simpool Acid Injection pump
    It does have a delay timer but the range is from .1 to 10 seconds
    Jun 2011
    San Diego California
    88
    Jerryt, can you let me know how your setup goes? Soudns liek you are ready to install, but ahve not yet. I think I'll be in a similar situation where teh 110V will be another task to run it into a seperate box (but not impossible), so I'm interested to hear how your 220V setup worked.
    IG, 13,000 gal, concrete, DE, VS Intelliflo Pump, Intellichlor SWG
    San Diego, Ca.
    Quote Originally Posted by markmac
    Sure thing, I have all the pieces. I just need some time and possibly an enclosure.
    SCHEMATIC HAS BEEN CHANGED
    The timer uses the NC terminal, first schematic was incorrect.
    Everything worked great, I used my existing enclosure.
    Jun 2011
    88
    Jerryt,
    Pm sent
    San Diego, Ca.
    Jerryt,
    Pm sent
    You can find the timer by searching "B1S-R-220" on ebay with the "include description" box checked
    http://www.ebay.com/dsc/i.html?LH_Title ... &_odkw=b1s
    Jun 2011
    88
    Final product looks really good. As soon as I can get the relay, I'm going to set up this configuration as well.
    San Diego, Ca.
    Jun 2011
    88
    Thanks to Susa and JerryT for all the details here. Just installed the relay and clock and works liek a charm. Now my Intelliflo basically runs the daily program, and when skimming, it will switch on the SWG.
    Time to add Salt.
    San Diego, Ca.
    Thanks everyone, this solution worked great for me.
    I have a simple system: pool,pump,filter,solar panels, bottom vac.
    Nothing to really control, the Pentair timer/speed is plenty, so I just
    added the current controlled relay.
    Using Ebay, I got an old stock relay and new chinese socket for just
    over twenty bucks. So much better than a multi-hundred dollar
    automation system!!
    Gary
    El Dorado Hills, CA
    Jul 2014
    Thousand Oaks CA
    9
    Susa do you have a wiring diagram? I have a 120v version relay but I'm having trouble figuring out how to wire everything up.
    Thanks
    Jul 2014
    Blue anchor, nj
    3
    I have a pentail programmable pump, I don't want to use the additional timer you have in the picture, would it still run correctly?
    Frank
    Quote Originally Posted by Baldwin88 View Post
    Frank
    Certainly, all this timer and relay stuff was for the IntelliChlor, not the pump.
  20. Back To Top    #20
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Frank
    A pentair intelliflow pump with a built in timer will run great wired directly to a circuit breaker and controlled from the built in control panel.
