Results 1 to 8 of 8
Thread: Freeze Guard and Pump Run Time afterwards
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    Question on Freeze Guard and Pump run times after it finally kicks off.
    Our freeze guard kicked on around 10 am this past Sunday and ran constantly through 1:00 pm on Thursday. So it ran for over 96 hours consecutively. For the next week it may come on occassionaly at night but not worried about that for the most part. currently my pump run schedule is for 8 hours a day to get just a bit over 1 turnover per day. I also have my cleaner scheduled to run for 2 hours per day as well.
    My TC is currently at 14 and that's another story for another day in regards to how it got that high.
    Now my question. Does it make sense or would it be feasible to leave the pump off for the next several days and only leave my cleaner on for two hours a day (pump runs when its cleaning) to help me recoup some electricity costs due to the freeze guard running or is this not what I should do?
    As always, any feedback would be welcome!
    thanks
    17,800 gallons, Pentair Clean and Clear 420 Cartridge Filter, Inground, Blue Granite Pebblesheen Interior, Pentair Intelliflo VS-3050 Pool and Spa pump, Pentair Whisperflo 2HP Water Feature pump, Pentair .75 HP Booster Pump for Pentair Legend pool cleaner, Pentair EasyTouch 8-function remote, Pentair IntelliChlor SWG.
    Feb 2008
    Denton, TX
    5,061
    Re: Freeze Guard and Pump Run Time afterwards
    As long as you don't defeat the freeze protection, I think that would be fine for a bit.
    May 2009
    Dallas, TX
    785
    My pump hasn't run at all during this cold spell, and the equipment faired well right through the freeze. I just drained the pump & filter and turned the equipment off at the circuit breaker to prevent the freeze protection from kicking in. Although it got very cold, it wasn't cold enough here to freeze buried plumbing. I don't know about Keller. And of course, this method wouldn't work for an AGP.
    Also, if you want to save on your electricity bill, you don't have to run the pump every day during the winter. I turn my water at most once a week during the winter with no problems whatsoever. And in the depth of winter, like right now, I go much longer than that.
    YMMV,
    Dave
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    Thanks 257 and Beez for the responses!!!
    Beez, i find your response interesting because i have been under the impression that the water should be turned over 1 time per day even during the winter time. when my cleaner comes on i have the pump turned up a bit to help skim the surface and get some of the leaves into the skimmers. if what i'm hearing you say is that i could just run my pump the two hours per day when the cleaner is running and not have to run it more than that as long as the water is balanced?
    Feb 2008
    Denton, TX
    5,061
    Beez' method is certainly an option. I think that a water turnover is really cold weather like this is less important than it would be if your water temp is greater than say, 60 degrees and you have a pool full of swimmers. You must of course maintain an appropriate FC in the water as just because it's cold doesn't mean things won't grow. The reason that I don't do this is that I do still want some filtering to take place (my pool is not closed) and I also want skimmer action and the cleaner to run.
    May 2009
    Dallas, TX
    785
    See this thread: Subject: What test are important in cold weather?
    The one turn per day is a good guideline. But ultimately the decision is up to you. Personally, I always test hypotheses before committing to them. And actually, this is advice advocated in Pool School under the heading: Determine Pump Run Time.
    *** This momentary departure is for the amusement(or horror) of Bruce ***
    This past summer I experimented with pump run time to determine exactly how low I could go. I ran the pump & polaris for only 3 hours a day(except for swimming days) for the entire length of the summer with absolutely no problems. Water stayed sparkling clear.
    CAUTION: NOT RECOMMENDED FOR THE TIMID
    OK, back to the subject...
    Consider those pools that are closed during winter. They get no circulation at all for months, but they are fine when opened. So if you turn your water once a week, or even once a month you are ahead of them! Anyway, the moral is do what works for you. If money was not a consideration I would run my equipment every day year round (and did the first year of ownership).
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    HA, the summer thing you tried is certainly NOT FOR THE TIMID!!!!!!!
    This great information to consume and consider. Another reason to love Trouble Free Pools!
    Thanks!
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by Beez
    Yep. Pools that are closed in September/October havent been circulated or chemicals added in 3+ months so far and still have another 3+ months to go.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
