Results 1 to 15 of 15
Thread: Deck Suggestions
    Deck Suggestions
    Planning our pool deck project for the spring, weighing our options and design - is there an overall consensus on what's best $ per $ (the type of deck)?
    We're looking at about a 700 sq/ft area.
    Example: we like the look of slate stamped concrete but is the texture ok for pool decks? does the sealer make the deck slippery? Do the edges of the stamped slate hurt the feet at all?
    I was also thinking of an exposed aggregate finish (w/ decorative pea gravel). Is the cost less than stamped? how is this finish on the feet? slippery with the sealer?
    Not interested in pavers, or a dull gray broom swept finish, although a colored broom swept finish might be an option.
    Any other suggestions? Anyone wish their deck was bigger or smaller in any areas? Was planning on a 3.5' wide deck round the perimeter with one large bump out for a deck and another small bump out (maybe 6') near the skimmer deck lid.
    Behind the concrete perimeter.. was thinking 2-3 section of stone, but that is probably not comfortable if barefoot. Grass might be an option but a pain to mow. Any thoughts on this?
    20k gal pool/spa, marc, Intellichlor SWG, 2 hp pentair whisperflo, Pentair clean & clear filter, Raypack Reheem 266 heater. Taylor K2005 test kit.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Deck Suggestions
    Well, my vote is pavers. Why dont you like them?
    At any rate, if you do with concrete, I'd do the stamped, colored variety. I'm not a fan of the exposed aggregate.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    SCEADU's Avatar
    Feb 2010
    Atlanta,GA
    68
    An "OleTimer" that I worked with in this industry had a very different outlook on all concrete decking. I heard him say it to several of his clients and I will now pass it on to you.
    1) there are 2 types of concrete. Concrete that "is" cracked...and concrete that "will" be cracked
    2) Stamped concrete is no exception to the above rule, it just cracks a little prettier.
    3) There is only one gurantee with concrete decking. That is that it will never get stolen.
    I push Paver for the cost, value, and longevity. If you do happen to get a spot the heaves or settles, the fix is siply pulling the pavers up and leveling the underlayment and then put the paver back down. If you ever want to add to them there is little concern to it not matching. If you ever choose to reconfigure your deck the pavers save you on time and money.
    Dec 2009
    2,690
    +1 all that. Except maybe cost. In most areas, pavers run a bit more than concrete. Depending on location, YMMV.
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    Sorry to hijack this thread, but what kind of Pavers do you guys suggest?
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    Dec 2009
    2,690
    I like Unilock. They have a lot to choose from. They have tumbled paver, smooth pavers, differnet colors etc.
    http://www.unilock.com/
    Quote Originally Posted by bk406
    Very interesting. Any experience with how hot these get on a hot (AZ?) summer day?
    RawhideKid
    Phoenix, AZ (Goodyear actually)
    Pool finally complete!!! IG, 40,635 gallons w/2080 gallon spa with 16 jets. Pool is 40x21 ft with 10 ft deep end; two baja steps
    Pentair Cartridge filter - 520 SQ. PebbleSheen interior. 2 Pentair VS pumps. Pentair Intellichlor SWG
    4 deck jets, 2 bubblers, fake rock grotto/waterfall with wet steps. 3 surrounding half-pergola's with misters in future
    Sunken covered ramada with cabinets, fridge, and wood fireplace. (soon to have big screen TV)
    Basically, 14 years of planning on how to survive this blistering AZ summer!!! WAHOOOOO!!!!!!
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    The house/pool came with concrete sidewalk style decking; it looked bad in the end: cracked and sunken in spots.
    We now have Belgard Urbana pavers in the greenish color, and we are optimistic that they will turn out over the years to be the better choice.
    Our surround is 4 feet wide, which is adequate almost everywhere. One side of the pool has a wide side for chaises longues that is 7 feet wide. This is the only bumpout area that is adequate; our 6-footer and 5' 6" bumpouts are not deep enough. They look nice, but the are not enough for the average reclining deck chair.
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Not sure where the OP is located but we are in Texas and the summers can be brutal! We went with the Spray Deck or Kool Deck product and all I can say is that it is great when it comes to hot sunny days and the bottom of ones feet. We had a streak of 100 degree days this past summer for 18 days, pool was used every day and not one of the kids said thier feet were hot or felt burnt on the deck. Now the natural stone coping is like a skillet in the summer sun.
    We looked at doing a agg deck as well as a salt deck, the spray deck was more but it looks great and the feel on the feet is great. Glad we went with it and would do it again.
    Good luck!
    JD
    23000gal. IG free form with waterfall
    mini pebble interior midnight blue w/Tahoe blue plaster
    OK flag coping, moss boulders and Idaho Quartz flag in waterfall
    Hayward SWG, Hayward 2-speed 2.5hp pump, Prologic Goldline Controls, DE 60 Filter,2-Hayward LED Lights
    2 skimmers, 8 returns 3.5'-8' Deep,Pool size 19'w x 36'L Salt version diving board,Polaris 480 Black cleaner
    Another vote for pavers.
    25x25x16 L shaped concrete, 4' to 6', 21,000 gal, PLP4 - Pro Logic System Control & Aqua Logic Salt Chlorine Cell, Hayward TriStar 1 HP, 24" Sand Filter, SunHeater Solar Heating System, ColorLogic Light, Jandy deck jets.
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    Those of you that have Pavers, did you do it yourself or had a contractor? I am on a budget so if we go that route, we'll do it ourselves. It would be interesting though as to what the cost difference would be between Pavers or a solid Cement deck.
    Dec 2009
    2,690
    You can DYI it, but its a lot of work if you have never done anything like it before. Getting the surface level, puuting a little fall in it away from the pool, and basically getting the grade correct is a must. Renting a plate compactor is also a must. If you were going to contract out concrete, you really should get estimates for pavers. You might find in your area its almost the same price. You wont know until you get an estimate. Like I said, you can DYI it, but on a scle of 1-10. I'd give it at least a 7. And dont even try the coping. If you want to DYI pavers thats one thing, but the coping is another ballgame. If you get a mason or concrete guy to do the coping, shooting grades for the paver deck is much easier.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,055
    Quote Originally Posted by Malibu07
    I vote for pavers too. Malibu07 you don't want to ask what we pay for pavers in Florida , however IMO I agree with SCEADU. Another reason we went with pavers is because they make a 1.25" version which was great because we wanted to match the flamingo lounge with the rest of the area. The flamingo lounge and some area outside had a poured concrete pad. Look at out sig bar for more info Hope this helps to the OP
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Dec 2009
    2,690
    Brent,
    We really need an emoticon intervention
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,055
    Brent,
    Sorry bk406 but I am a very passionate and excited individual. Cheers
