Thread: speed control on pump motor
    I have a 1.5 hp hayward pump. Can I put some kind of speed control on the motor to get variable speed or will that damage motor?
    If not can I swap out motor instead of buying entire pump?
    it's a matrix power flo matrix with ao smith motor
    thanks
    thanks
    gary
    24ft x 54" aquasphere mission agp, cartridge filter, 1.5 hp hayward, TF-100, BBB method, pool install July 2010
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Re: speed control on pump motor
    If you want a 2-speed pump, you're going to need to swap the motor for a 2 speed motor. Variable speed, you'll need a new pump. I just did a motor swap on my 1hp Sta-Rite and it was really easy, only a couple hours work. Good luck!
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    22,553
    If you had a 3-phase pump it'd be easy to put a drive on it but with a single phase, it's gonna require a new motor. As GuamGuy said, it isn't a hard job. I recommend replacing the shaft seal when you change the motor just for good measure.
    mas985's Avatar
    Pleasanton, CA
    11,742
    They do make single phase variable frequency drives but by the time you purchase the drive and the enclosure, you might as well upgrade to a variable speed pump. Also, a standard motor usually does not have the appropriate bearings for a variable speed drive so you will likely shorten the life of the motor.
    Mark
