No, that is normal so long as their is algae in the pool. The combined chlorine is chlorine combined with organics in the algae. Once the algae is completely gone, the CC should return to normal. To the extent that you can physically remove the algae via brushing and filtering out the algae and backwashing or cleaning your filter (depending on type of filter), then that will speed things up since it can take longer for chlorine to oxidize the algae, especially when there is a lot of it.vwtoys said:The chloramine readings is staying at .5 to 1ppm. Should I be concerned?
Not yet. Some light brushing is removing the top layer which has turned more of a dark green color. Once brushed off, a fresh/lighter green color is now exposed again but it's not as dense. I'm guessing the chlorine hasn't had a chance to attack the stuff covered by the dark green layer (which I assume is dead algae). The pump is running and the water is still very clear.PoolGuyNJ said:I wouldn't sweat the CC level.
Have you tried to vac out the dead yet?
Scott
chem geek said:No, that is normal so long as their is algae in the pool. The combined chlorine is chlorine combined with organics in the algae. Once the algae is completely gone, the CC should return to normal. To the extent that you can physically remove the algae via brushing and filtering out the algae and backwashing or cleaning your filter (depending on type of filter), then that will speed things up since it can take longer for chlorine to oxidize the algae, especially when there is a lot of it.vwtoys said:The chloramine readings is staying at .5 to 1ppm. Should I be concerned?
It depends on your CYA level.What's the recommended level of chlorine?
duraleigh said:It depends on your CYA level.What's the recommended level of chlorine?
If you will post test results called for in Pool School, we can give you far better advice.
salp said:I did a speed read over the thread. Have you cleaned your filter since you began this process? You might want to do this... Are you running your circ pump 24/7? If you are already at 9ppm, I would try to keep your shock level at 15ppm to help kill the remaining algae. Per your numbers, your shock level should be around 11ppm or higher.
Where in California are you?
Thanks. The pool water is crystal clear and has been (at least visually) before I started attacking it with chlorine. It was just the green algae that has been impossible to brush off. I guess this isn't the regular mustard algae that could be brushed off easily in the years past. It's much more resistant to brushing. The pump will be running 24/7 the next few days.salp said:With your situation, you really need to be running 24/7 until algae is gone. FC level looks great. Clean your DE Filter, you will win the battle!
The green "algae" that you see in the first pic, where the two large dark green patches are on the wall, have been there the longest. It has literally spread all around the pool in the last month. With the constant shock level (right now at 16ppm) the newer stuff has mostly died off. Almost all the stuff on the bottom has been killed. I still have a much lighter green where the 2 large patches are. But IT IS a lot lighter in appearance. I think I'll give it a few more days and see if it fades more. I'll post a picture when I get sunlight. I have not rubbed it with a trichlor. It is pretty cold and I'm hesitant to jump in. :lol:dmanb2b said:VW...pretty solid advice thus far . Also, I may have missed it, but given the "algae" on the side is so stuborn, have you tried rubbing the wall with a trichlor puck to confirm it is in fact organic? You seem to be at shock level so with the constant brushing I struggle with why it is still green, unless your CYA reading is off
