Thread: Pump/filter run-times
    Prav's Avatar
    Nov 2010
    Miami, FL
    94
    Greetings from the only state without snow!
    I see a lot of posts where it says the optimal run-time is whatever turns the pool over once a day. My question is: do I *have* to run the pump every day? Or just maintain FC at target + 2. For the record, the last set of numbers:
    FC: 5
    pH: 7.6
    CYA: 50
    Alk: 100
    CH: 250
    Borates: 50
    Temp: guessing 70ish
    My thinking: save some electricity (50% if I run the pump every other day instead of every day). Sanitation should be fine because not being used (and there is still FC). Algae control should be fine (helped by the borates). Yes, there will be surface debris that would make the pool "dirty" rather than optimally sparkling, but I can live with that.
    As long as the numbers stay well above min, I shouldn't have issues, right?
    14'x30' (est. 14K gal) w/spillover spa (est. 500 gal) - 1995 // Diamond Brite Blue Quartz - 2006
    Hayward SwimPure Plus T-15 - 2013 // Zodiac MX-8 - 2013
    Plain ol' Intermatic mechanical timer // Pump: 1 HP Pentair SuperFlo - 2012
    Filter: Hayward C17502(S) Cartridge Filter - 2011 // Heat Pump: Sunrunner/Aquapro 1300 (127K BTU) - 2011
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Pump/filter run-times
    I'd say you'd be fine. If you are swimming, I'd run it daily and always when there are swimmers in it, but if it's not used, just do what it takes to keep it looking nice.
    Feb 2008
    Denton, TX
    5,061
    Echoing what JohnT said, I am also for running the pump every day while open. You essentially want to turn the water over at least once per day. Experiment with it and see what happens.
    susa's Avatar
    Oct 2010
    Deep South
    578
    greetings from a couple hours south of you. I *do* run 24 hours/day but it is because I have total control over the power use of the pump. At 90-95 watts it costs very little, is totally silent and the low flow rate keeps the pool extremely clean. Before I had the IntelliFlow VF and ran conventional single speed pumps, I hated the noise they generated and actually used more power in running 4 hours each day compared to the VF running all day.
    Pacifica's Avatar
    Mar 2010
    San Diego, CA
    47
    If you are set on saving electricity, it would be a good idea for you to install a variable speed pump. Check with your power company and ask if they give rebates on installing a variable speed pump. You can save anywhere from $30-$60 per month depending on current situation.
