Thread: Aqua Logic P-4 Automation System
    Today I put my system into super chlorinate mode after two days of heavy rains. Everything seemed fine until this afternoon when I noticed the filter was off. There was a Check System note showing a Low voltage message. I reset the circuit breaker, now there is no message, but the filter will not turn on and neither will the lights.
    Help Please!
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Aqua Logic P-4 Automation System
    Welcome to the forum
    The P-4s have been known to have power supply issues and having the cell in superchlorinate mode may have pushed it over the edge. Check the web site http://www.nocellpower.com and see if that might be your issue.
    Mark
    I did that. Resoldering did not seem to work, granted I didnt take a whole lot of time with it. Is is strange that there is no error message now? If the K1 relay was the problem, would that keep the filter from turning on or would it just affect the chlorinator?
    mas985's Avatar
    Pleasanton, CA
    11,741
    It sounds like a power supply issue. I know that others have had issues with the transformer and the bridge rectifier which would affect the relays. Have you checked the voltages from the power supply? Also, there is a fuse on the board that you might check although I think if that burns out, the whole unit goes black. You might search the forum as there are many threads on P-4 problems.
    Mark
    I did check the fuse (have had that go out a few times) and it is ok.
