Thread: calcium hardness
    calcium hardness
    My CH is 85ppm from the tap. I was told by my dealer that the hot springs spas are required between 50-150ppm. Am I safe with it at 85 ?..on here you say 100-130.
    thank you.
    22,549
    Re: calcium hardness
    In any case you need to follow the mfg's recommendations to preserve any warranty. Besides that, low CH will cause issues in anything except vinyl.
    maybe i'll add just a teaspoon.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    In a spa, low CH sometimes causes excessive foaming. If you don't find that to bean issue, 85 is fine in your spa.
