Thread: Alternate method of removing baqua-****
    I also found an alternate method of removing baqua-**** from my pool. I'm using non-chlorine shock - but it seems similar to your method. I found it on poolcenter.com, http://www.poolcenter.com/how_to_con...biguandes_.htm I'll let you know how it turns out, we started on Friday.
    - Marianne
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: How to convert a Baquacil pool to chlorine
    While you can use lots of non-chlorine shock or can also use sodium percarbonate to get rid of Baquacil, it's a lot more expensive than using chlorine, though is a lot less colorful and is generally faster.
    Thanks chem geek - i spent about $80 on the non-chlorine shock powder - good news is that I have 2 bags left over!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Alternate method of removing baqua-****
    Also, shouldn't the filter be cleaned after conversion, not before
