Page 1 of 3 123 LastLast
Results 1 to 20 of 47
Thread: underconstruction spool, help with plaster, decking....
    Spool under construction. needs help with Plaster,decking...
    Hi everyone,
    I'm totally new for all of that & I would really appreciate any help, advice or opinions.
    I started my spool construction 2 weeks ago, it's a 18" raised freeform gunite build 17'length x 10'wide & 4-4.5' deep with artificial rocky waterfalls, grotto, 8 jets distributed 26" apart at different height levels from the seating deck that's located on one side only of the spa. Please check attached plan.
    The equipment to be installed is:
    Pentair "Master Temp" heater(400,000 btu)
    Pentair "Intelliflo" variable speed pump.(circulation/jets)
    Pentair "Whisperflo" 1 1/2 horse power pump (waterfall)
    Pentair Cartridge filter
    Pentair salt system
    Pentair color light.
    Intermatic time clock.
    I'm still confused about a lot of remaining details, like the plaster finish, tile to be used, decking around...
    We are using the dark brown color for the rocks, three river flagstone coping & veneer stone for the outer side.
    Is it ok to use a French gray plaster for this kind of spa? We are interested in dark/medium blue colors & at the same time I'm afraid the steps in gray will look so dark/cheap or may be the spool is too small to reflect this kind of dark plaster
    I took care of the design & equipment but have no idea on how to finish the inside of the spa & the decking around to get the look we dream of (like a natural lake with little waterfall)
    I will be posting Photos of how we are progressing with our project & wait for your opinions & suggestions.
    Thanks in advance.
    [attachment=0:3ti9ifid]spool graph.jpg[/attachment:3ti9ifid]
    Hi everyone,
    Pentair salt system
    Thanks in advance
    [attachment=0:2eqfw9zn]pool plan.jpg[/attachment:2eqfw9zn]
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: underconstruction spool, help with plaster, decking....
    Mina...welcome to TFP This is a slow time of year on the forum, but fear not, someone with pool building knowledge will be along shortly to provide you with guidance and opinions. I have merged you're 2 posts as we do not allow double posts on the forum. It's not that one area receives more attention than the other, it's just slow in the pool/spa building arena for most of the US.
    Nov 2010
    152
    The color of the interior surface is mainly a matter of personal preference. The basic design seems to indicate your preference for a "natural lagoon" look. In my opinion, the grey/blue surfaces should tend to be background colors, allowing the eye to be drawn to the surrounding water features and landscaping, rather than the interior of the pool. One of the "pebble" surfaces inside might tend to blend it a bit better with the surrounding dark brown stone, but they cost more too. You also have the option of using flagstone to cap the steps, so it will pull the color of the stone down into the pool. If you choose to do this, have them make the steps shorter, then add 1.5"-2" of flagstone to make the steps' height meet code.
    Tile choices are personal preference as well. Based on your description, my preference would be a tile that matches the flagstone with other colors like blue/rust/green to blend with other colors out of the surrounding area, but you can look thru tile catalogs from many tile supply companies & find the one that you like best.
    APSP CST Certified
    17k inground concrete; 1.5hp 2 speed Tristar pump, 300sq.ft. Cartridge filter, AquaLogic PS-4 w/ Tcell-15, Navigator suction cleaner.
    Thanks Ranger,
    I'm actually using the flagstone for the outer steps & the coping, the steps inside!!! I'm just afraid that flag stone inside the water will be high risk to get the rust problem & mess with the full thing.
    I'm posting here some photos of what we reached so far.
    It's a lot of mess after the rain, they have to cover it as it started to rain right after the gunite was done. the cover ended down in the spool with a lot of rain
    The photos will cover/show the following points
    - the left side (seating & jets)
    -the 3rd step added at the final stages (was not Planed)
    - the grotto & the water fall to be
    - we will try to match the veneer stone in the fire place for the spool outer wall
    - we will try to match the same stamped concrete in the patio area for the whole backyard
    - equibment behind & under the waterfall rocks
    more photos
    & more
    I think it's leaking, The water level after the rain was just a little above the seat now it's 3" below,
    I just have the gunite, Is there a sealing material that they will apply later to prevent leakage????
    Is that the Pool finishing/ Plaster????
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,074
    Mina I posted a comment in your other pool forum. Trust me you will be very happy with the size of your pool. We at one point thought our spool was too small however as it turned out it is plenty big enough for all to enjoy. Besides you will find that smallers pools cost less to maintain, clean and cover if using a solar cover, and also will heat and cool much quicker in the winter and summer Keep the pics coming
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Thanks Brentr for the postive reply,
    I just hope no more problems to come, I'm trying to be flexible with a lot of errors but this width thing is what ****** me off.
    Any way, I had a meeting today with my PB, we are going to resume work today, we are doing the rocks for the water fall/grotto & the steps up to the spool.
    I will post photos soon
    Nothing much, the Rock guy is here working with the waterfall, rocks & some water proof material.
    I Still have the feeling these rocks are really big for the spool size , the rock guy said: wait till the steps are done & the flag stone is added
    The left rock is open, ready with water supply & drainage pipe to have a planter inside the rock
    Some more done, I really liked the rocks now, I think they will start coloring it (brown, volcano red...) today or tomorrow.
    Three river flag stone cut & ready for coping...
    Give me your opinion, any ideas or comments are welcome.
    Thanks & best regards,
    Three river flag stone coping
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,074
    Your spool is really starting to look great
    Thanks Brentr
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    That's a really nice design. I really like how they made the rock mountain. Is that simply concrete manicured?
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Hi Xs,
    yes, the Rock man is really talented. he is playing with the concrete like playdoh
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,074
    Mina, don't forget to have intellibrite lights installed. Look at this thread http://ths.gardenweb.com/forums/load/po ... 28228.html
    We went the cheap route in the beginning but ended up changing
    Wow Brentr,
    You gained a lot of experience with your pool & you made a lot of friends here as well, Thanks for the advice.
    for sure I will consider the intellibrite lights, I'm sure it will be great on the waterfalls & the grotto
  20. Back To Top    #20
    Apr 2010
    Buckeye, AZ 85326
    619
    I gotta say in the first pics I was thinking maaan what is going on up in here! But now I see the light. It's coming together nicely. Is the flagstone manufactured or natural stone?
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
