Results 1 to 8 of 8
Thread: Thisisme
    Dec 2010
    Turlock, CA
    8
    Thisisme
    Greetings,
    Just stumbled upon this site and it looks good. Hopefully I'll be able to learn much here and maybe even add something intelligent once in a while.
    I have a small in ground pool in the Central Valley of CA. My pool is a about 5 years old.
    Mike
    8,500 Gal. IG, Plaster, 2HP Jandy Stealth Pump (pre 2006), Jandy CL580 cartridge filter, 2 24" Jandy Sheer Descent waterfalls, Heliocol roof mounted solar heating.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Thisisme
    Welcome to TFP Mike
    Be sure to check out pool school (button on upper right of the webpage)
    Also, good time to add your pool specifics to your sig. You can find the instructions here
    30,432
    Re: Thisisme
    Hi, Mike,
    Welcome to the forum It's pretty quiet here now but stick around in May and June......this forum explodes. We're glad you're here.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Thisisme
    Mike, welcome to TFP!!
    It's about time someone added something intelligent here
    Luv& Luk
    -Ted
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Thisisme
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Thisisme
    Welcome!
    You will learn a lot, guaranteed. The learning curve is sorta steep, but that only lasts about 3 weeks, then it's easy. I'll warn you right now that the first time you actually ask anything, your first reply will ask you, "Can you post a full set of test results?"
    You will need a test kit to play the trouble-free way. There's an article in Pool School about them. Or just skip that part, go straight to http://tftestkits.net and order a TF100 and a speedstir. Best money you'll ever spend on your cement pond.
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Re: Thisisme
    Mike,
    Welcome to the best forum on the net.
    What Richard said... and also add your pool specs to your signature.
    -Ken-
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    Feb 2008
    Denton, TX
    5,061
    Re: Thisisme
    Welcome to TFP!
